Battery change out
Battery change out
I was told when replacing the battery used to start the bike with a siren security system, that all you had to do was make sure the fob was within close enough distance to disarm the security system while changing out the battery and this way you'll have no problem with the alarm system. Is this correct procedure, or is there some other trick to replace the battery without setting off the alarm, or having it work correctly after install of battery.
Thanks Jonnierock
Thanks Jonnierock
what you have to do is to turn your ignition on with your fob nearby. then after the alarm has deactivated, switch the ignition off. between the time that you have switched it off, and when the alarm activates, you have a second that you wanna pull the maxi fuse. that will keep your alarm from going off and the battery back up on the siren from sounding the siren.
Recently replaced mine. Followed instruction in Owners Manual. 2014 Dyna
Removing old battery:
FOB near bike turn ignition ON to disable alarm.
Disconnect negative cable first. Then positive.
Installing new battery:
Connect positive first. Then negative.
Turn ignition off.
That’s it
Turn ignition off.
That’s it
Turn ignition off.
That’s it
Turn ignition off.
That’s it
That's exactly how is says to do it in the manual, but when removing the battery the with that procedure the headlight and taillight are on, correct ? And that worked.
