Oil Change Today
Oil Change Today
I did a quick search and didn't find anything. I have a '16 RG.
My owners manual and HD service manual both say the engine oil capacity is 4 quarts. They also say add 3 quarts, then add whatever needed to bring it up to the proper level.
I changed the oil and filter. I also disconnected the cooler lines and shot some compressed air through just to see how much oil would come out. About 2 oz.
I added 3 qt., ran it at idle for about 3-4 minutes, shut it off for about 5 minutes and checked it. It was right in the middle, between the hot mark and add 1 qt. mark on the "bike straight up" scale.
Every time I ride it I check the engine oil. As people here know, on the dip stick it says "screw it in" or something like that. I was expecting to put about 3.5 qt. in.
Just checking with the brain trust here to make sure everything is cool.
The following 2 users liked this post by vizcarmb:
Joe from So Cal (04-22-2019),
SPRINGER (04-23-2019)
Joe from So Cal (04-23-2019)
The following 2 users liked this post by IdahoHacker:
Firebike32 (07-05-2021),
IdahoHacker (04-23-2019)
Probably has to do with how long you let the old oil drain. I never left a 1/2 quart in the bike but there are times a few ounces are leftover. Dump in 3.5 quarts and its almost always good to go, now and then I need to add a few ounces to get it up around the half way mark on the dipstick.
I replace all 4 quarts but I use a Scavenger Oil Changer Kit. I don't like the idea of leaving contaminated oil in the engine when I do an oil change.
The following 2 users liked this post by Route66:
attaboy15 (04-26-2019),
Joe from So Cal (04-27-2019)
