1999 Dyna wide glide location of fuse box
06-04-2019, 06:44 AM
For the life of me I can’t find the fuse box it’s not under the seat.
06-04-2019, 07:11 AM
Square panel on the left side, remove the four screws
06-04-2019, 07:48 AM
Quote:
Originally Posted by
Architect
Thanks I finally found it but all fuses seem to be good and still no spark. Ive replaced the coil the battery I have horn and lights can't figure this out....
06-04-2019, 09:27 AM
Is it turning over at all?
06-04-2019, 09:48 AM
06-04-2019, 09:52 AM
This may be silly, but have you tried it while in neutral?
Mine won't do anything while it's in gear. I can only get it to turn over when in neutral. (Started doing it randomly after about two years of being able to crank while in gear)
06-04-2019, 09:59 AM
I believe it’s in neutral because he’s trying it while not sitting on it.
06-04-2019, 11:40 AM
Battery, or the connections????
06-04-2019, 11:42 AM
Nope new battery and checked the connections for tightness.
06-04-2019, 11:48 AM
If it's not even turning over, check the relays. Should be two, and they look like this:
