Dyno - dealer vs non-dealer
Your bike "feels" slower because the second guy told you he had it running 76/75 after the first guy told you he had it running 79/78.
But it's in your head. You can't feel a tiny difference like that.
There is the possibility that the second tune has the bottom of the RPM range all screwed up, so your torque curve has a sharp slope to it instead of being flat. That will make it feel more sluggish.
You are still detuning the bike to a degree, the tuner manufacturers all agree on this. Yes, some combinations you can remove it by advanced programming on some combinations, usually by cutting off the fuel and sometimes adding fuel IIRC, at certain times.
But, yes it is normal in a performance motor and a stock engine, I stated normal, not necessary. Under normal circumstances and none of the previously mentioned problems are causing it, it does no harm.
But, don't take my word on this....https://tech.bareasschoppers.com/exh...ses-solutions/ and there is a nice rundown on things to check.
Bareass Choppers has some good info in their link, but it isn't an "end all" treatise on decel pop by any means, and some of their statements aren't, in my experience, totally accurate. For instance, in a properly tuned bike, "blipping" the throttle while downshifting should not result in any decel pop (one certainly doesn't normally hear race engines of any type exhibiting a whole lot of decel pop). It certainly doesn't with my bike. Neither does decelerating under light throttle openings. While my bike admittedly isn't dyno tuned yet, it's seen the benefit of quite a bit of autotuning and other tweaking and runs strong and smooth with no indications of running either rich or lean and with only an occasional (and I mean very occasional) burble on decel.
Your quote: "You should be aware that if your map was made or tested on a dyno to work for your bike then you will actually be detuning your bike doing this."
Dyno tuning generally is geared toward optimizing performance, not sound, last time I checked. A dyno tune might not even touch the decel settings in the original map. Tweaking decel settings can't automatically be considered to be "detuning".
The bottom line is, you're assertions don't agree with the experiences of quite a few others, and certainly don't agree with mine.
Done here. Just my couple of pennie's worth, based on my experiences.....
I ride with 4 guys that all have motor work done. S&S kits, different cams, some with head work, 4 tuned with TTS and 1 PV. Not one of our bikes decelerations pops. Might be different on a sporty but if my bike deceled popped it would be going back to the tuner. That would be unacceptable .
Received 5,388 Likes
Originally Posted by TimmyPage
I like the way they look and sound too much but thanks.
Well then, ok.
Well then, ok.
pgrchaplain (06-20-2019)
+1 on a 2 into 1; other the WFO throttle, a 2 into 1 exhaust will provide better performance for street riding; but if style and sound matter then it's your bike and your money.
The difference, perhaps imperceptible front he seat of the pants could have been due to slight variations in tune or atmospheric conditions from different days.
So much attention is afforded deceleration popping. It is unburned fuel making its way down the exhaust path until it matches with enough oxygen for ignition. On the street it may be, well, annoying but is not, by itself, indicative of a "bad' tune.
Received 3,988 Likes
Absolute dyno numbers are meaningless junk. A good dyno operator can make the dyno read anything he wants. An inexperienced dyno operator gets whatever meaningless number the dyno spits out.
ETA: The only thing a dyno is good for is comparing differences in the same engine. There is no absolute comparison between two dynos or between two dyno operators. The best you can hope for is to use the SAME dyno, the SAME operator, using the SAME settings with the SAME atmospherics. A good operator will make the dyno read whatever he thinks will bring repeat business.
