What are these called?
09-22-2019, 05:11 PM
What are these called, and what’s the best way to turn them gold? Vinyl wrap? Spray paint?
09-22-2019, 05:18 PM
I call them push rod tubes but that may not be the proper description.
I have no idea as to how to get them in a gold color but keep in mind that there is a lot of heat in that area so I'd question if any type of wrap would endure for long.
09-22-2019, 05:20 PM
Pushrod tubes is correct.
Turning them gold would probably best be done through electroplating.
09-22-2019, 05:21 PM
Push rod tubes. Pull them out and have them powder coated or anodized.
09-22-2019, 05:24 PM
Sure you want to do that? You have to pull off the cylinder heads to remove them on a 5 speed Sportster.
Go online and buy them. Try J&P Cycles , Drag Specialties or V-Twin Mfg. Shouldn't be hard to find gold pushrod tubes. They do look kind of cheap and gaudy when you get them on though.
09-22-2019, 05:26 PM
Quote:
Originally Posted by
Tommy C
It's not as bad as all that!
You can remove them via the little mounting blocks at the bottom.
09-22-2019, 05:31 PM
Get a flathead - you won't have to mess with them.
09-22-2019, 05:40 PM
Vinyl wrap and olive oil....trust me, it's a time tested recipe.....
09-22-2019, 05:55 PM
RFG7680
Will they get too hot for powder? Cerakote or ceramic, but they wont be gloss.
