2008 glide
2008 glide
I have put 9° triple trees from Tricky Air for my 08 street glide..... I only have about an inch travel and bottom out...Test ride down the street And all seems well unless I hit a bump and bottoms out... do I need to put stiffer springs in , change volume of fluid etc.... I hear about shocks when they hydraulic lock and don’t understand that situation...
You might see an older post that I put on pertaining to the bike having a wobble I needed help. I have worked with it and change several different things and realized the problem was the rear shocks. It had nothing to do with the front end having a triple trees changed.
heavymetalthunder
10-13-2014 10:28 PM
