Warranty question.
Old Feb 23, 2020 | 08:10 AM
Siggi Langnasen's Avatar
Siggi Langnasen
Default Warranty question.
I'm going to be moving back to Japan at some point and intend to purchase a new M8 Fatboy. Being aware of the sumping issues (etc) I don't want to void the warranty but would like a Stage-1 setup, to include the breather, baffles-out V&H short-shots and a fuelpak. Will any of that void the warranty if installed by the Harley dealer?
TIA.
Old Feb 23, 2020 | 08:17 AM
ghost183's Avatar
ghost183
no, but the issue is the V&H, chances are only THAT dealer will honor the warranty
your best bet is have them install the stage 1, and YOU buy the V&H without telling them,, you can always remove it to take the bike in for warranty work if needed.. it doesnt leave an imprint on the OE ECM
i went thru the same thing when i exported my CVO, but i had ordered the bike with a stage 3 HC kit, so my original dealer invoice stated the stage 3, which they put in the system so i was covered here in greece, all this happened before i took possession of the bike.. but it was ALL HD parts, no V&H
Old Feb 23, 2020 | 08:18 AM
Iceman24's Avatar
Iceman24
If HD installs...No.
Old Feb 23, 2020 | 11:53 AM
Oakers3's Avatar
Oakers3
With cars the Warranty does not transfer to other countries other than Canada. You could purchase an extended service contract, extended warranty, when you get there. Bikes may be different.
Old Feb 23, 2020 | 01:09 PM
skratch's Avatar
skratch
that's not correct. in the owner's manual, they even spell out that they will sell and install components that may impact your warranty. just because the dealer sells it, does not make it warrantable.
Old Feb 23, 2020 | 06:05 PM
TimmyPage's Avatar
TimmyPage
A V&H Fuelpack will void your powertrain warranty. Doesn't matter who installs it.
Old Feb 25, 2020 | 02:10 AM
Siggi Langnasen
Thanks guys. So, obvious follow-up question...if I installed a fuelpak, then uninstalled it, does the stock ECM hold a record it was installed that a technician could spot?
I see Ghost says not.
Old Feb 25, 2020 | 06:49 AM
CaffeineBuzz's Avatar
CaffeineBuzz
I would prefer there be a clear line. If you cross the line, you void your warranty.
There is obviously no clear line.
Old Feb 25, 2020 | 07:05 AM
skratch's Avatar
skratch
the Harley digital tech will definitely be able to tell that your bike was flashed by a non compliant tuner. whether or not you return it to the stock map, it will still leave a detectable footprint behind.
not to mention, that it is an automatic thing. dealers have been directed to plug your bike in to the digital tech if you bring it in, regardless of what you bring it in for, and the tech will pick up that footprint and automatically flag your bike in the system.
Old Feb 25, 2020 | 12:07 PM
slw210's Avatar
slw210
There is a clear line, read the warranty. Any Off Road only parts will void some or all of warranty, so does putting on a trailer hitch, been in there for a long time. Some dealers will sell you things and install them and still fix your bike when it breaks, that's them doing you a solid. EPA is trying to discourage that, write your Congressman/woman and your Governor and who ever else you like.
Haven't heard of any Softail sumping issues. Are they going to let you ride that in Japan? Just curious. Can you buy it in Japan?
blackflame
May 10, 2017 07:02 PM
borican1979
Mar 5, 2014 07:08 AM
mswing1234
Sep 23, 2011 04:28 PM
Gary86
Jun 26, 2011 05:54 AM
itimmers
Feb 16, 2011 11:57 AM
