Stainless Riser Top Clamp Cap Screw?
Reaper's original riser top clamp cap screws are grungy/rusty, so I am considering replacing them with stainless steel cap screws. The question I have is: will they be strong enough with the 16" apes I run?
Any experience/advice with this is appreciated.
Cheers!
Cheers!
The following 2 users liked this post by Jackie Paper:
AliensilverFXDBI (02-21-2021),
Clammy (02-21-2021)
off the shelf hardware store stainless hardware is very close to being grade 2 quality, there may be Stainless stuff out there (better alloy) that is stronger, and if you can find them use them
304 series Stainless comes in just under Grade 5 strength
The issue with stainless is getting torque values without galling the threads.
You can use anti seize but be aware of the difference in torque values for not only the Stainless, but the effect of anti seize on torquing.
Personally I reduce the number 20%
Replace the hardware and dab it with gloss black paint, or try to find good bolts that were chrome plated, again watching out for Chinesium junk hardware
Clammy (02-21-2021)
Received 32,874 Likes
Damn! You don’t screw around with your screws do ya? You must know your chit.
Rain
05-19-2012 08:44 PM
