Biker Bells: Where to hang?
Old 08-16-2007, 07:32 PM
Big Pa's Avatar
Big Pa
Big Pa is offline
Default Biker Bells: Where to hang?
I was educated in a prior thread about the Guardian Angel bells and was wondering if there is a specific place you are supposed to hang it. Or does it matter? My wife is getting myself and my brother one this weekend.
Joe
Old 08-16-2007, 07:35 PM
Kolni's Avatar
Kolni
Kolni is offline
Default RE: Biker Bells: Where to hang?
Hang it as low as possible.
I put mine of the frame hole right behind the front tire.
Old 08-16-2007, 07:41 PM
DavyDiesel's Avatar
DavyDiesel
DavyDiesel is offline
It should come with a little printed instruction, but:
The giver should be the one to hang it. (has more power then)
It should be hung at the lowest possible place, otherwise when the bell jingles and the gremlin falls off, it could attach to another piece of the bike on the way down.
Old 08-16-2007, 07:44 PM
bcox's Avatar
bcox
bcox is offline
Hung mine under the coil off a wire that was there.
Old 08-16-2007, 08:52 PM
YUCK's Avatar
YUCK
YUCK is offline
Left nut or right nut,,,,,,too many choices....
Old 08-16-2007, 08:56 PM
oldfartjc's Avatar
oldfartjc
oldfartjc is offline
I hungmy bellright below the right floorboard onit's bracket.
Old 08-16-2007, 09:04 PM
SiLlY's Avatar
SiLlY
SiLlY is offline
ORIGINAL: bcox
Ditto.
Old 08-16-2007, 09:11 PM
cardboard's Avatar
cardboard
cardboard is offline
Under my brake pedal there's a rod with a pin going threw it with a ring on the end. I hung mine there.
Old 08-16-2007, 09:13 PM
helixhippie's Avatar
helixhippie
helixhippie is offline
Mine hangs from the ground wire that runs under the V Regulator
Old 08-17-2007, 12:51 AM
ROADRAGE98's Avatar
ROADRAGE98
ROADRAGE98 is offline
I hung mine on the first cross member on the frame from the front of the bike.
Quick Reply: Biker Bells: Where to hang?
