It's waaay too rich...
...and the guys at the shop I bought it from told me that I 'just need to ride it harder, just blow it out and don't ride so slow.'
I ride this '79 shovelhead to work running about 55-75 mph. So I guess that's slow.
I think it's more that the bike is jetted too dang rich. The inside of the drag pipes is coated with carbon, the plugs are carbon fouled within 4-5 days of installing new ones. Granted, the mornings lately haven't been very cold, but to require no choke (enrichener, actually-it's an S&S Super E carb) to start cold is a bit suspect in my experience.
So, I'm off to another bike shop tomorrow, so see a mechanic who is a fellow Shovelhead enthusiast. We'll see if we can get this fixed.
Kent
'79 Shovelhead FXE/FLH hybrid
Kent
RE: It's waaay too rich...
ORIGINAL: zombie
Sounds like the beginning to some bad nursery rhyme...
Jack's rat could eat no fat
His bud's bike ate too lean...
Took em' both to a tuner
With a dyno machine
Now they both run really mean...
With a dyno machine
aw crap, my dogs eyes are tearing up...
In my experience the S&S carbs are very difficult to tune properly, however when done theyperform well. The dealer for the most part is clueless when it comes to other than stock equipment. Maybe an Indy may be able to help you. There is loads of information within this site whichmay lead you to the correct tune. Your bike is running rich and you shouldn't have fouled plugs, but there may be other indicators represented by your inherent situation which may lead you to correct the problem.
ORIGINAL: DavyDiesel
ORIGINAL: zombie
With a dyno machine
With a dyno machine
ORIGINAL: notorious
Results- Jezebel runs better at wide open throttle, the same stumbling/popping/chugging on part throttle. Idle is sometimes better, sometimes worse. I just pulled the plugs to check them after riding the bike home from the bike shop, then to work and back today. The plug from the front cylinder is carbon fouled, but not nearly as bad as before the main jet change. The rear plug is also not as badly carbon fouled, but in addition, the center electrode and its insulator are lighter gray...indicating that maybe I'm getting closer to the right jetting.
The mechanic at the new shop recommended changing to electronic ignition. It's tempting, really tempting, but it is also about $200 for a Dyna double fire ignition. I'm also thinking about going to a 28 intermediate jet, see how that works, maybe go to the next size down on the main. Maybe not. The pipes are turning a straw color; before they were only blueing up near the head.
Kent
'79 FXE/FLH hybrid "Jezebel"
It is well worth your time to go to the S&S website and download the .pdf file for the S&S Super E. Then you can order jsets from anyone of a dozen catalogs and jet it yourself.
Dialing in an S&S is a hell of lot easier than Dialing in a Mikuni, at least to me and I've owned multiple units of each carb over the years.
You are on the right track, I've found the S&S to be the easiest tune of any carb I've had in more that 45 yrs riding and working on bikes. Once you get it right you won't have to screw with it unless something changes on the bike. Because of all the variables, carb tuning is a bit of an art but not rocket science. Good luck.
Switched from points to Dyna S on my Evo, definitely worth it. Keep the old points setup in your toolbag in case something does happen its a no brainer swap.
