Fuel Additives ?
Old 10-05-2022, 09:58 PM
Old Patriot's Avatar
Old Patriot
Old Patriot is offline
Default Fuel Additives ?
I bought a Softail with EFI last month that had been sitting for 4 years. Owner denied it, but I think the fuel was 4 years old, too since it hadn't been registered since 2018.
It ran a little rough, so I added half a can of SeaFoam to 'clean-things-out'. Now, about 2 weeks later & having added another half can to a fresh tank, my Fuel Quick Disconnect began leaking.
I got the 'Fuel Tool" brand rebuild tool (so easy) and their valve, spring & O-rings and set to rebuilding the check valve. While removing the lower O-ring, the valve & spring just fell out. Seems the top O-ring was non-existent. I'd recently put a few hundred miles on it so I was really shocked. It is always the bottom O-ring that so commonly gives out.
Seems the top O-ring was completely dissolved VERY recently. I'm quite certain most everything on the bike (2005) is OEM, which is 17 yrs old.
I've read the OEM O-rings of pre-2012 do not hold up to ethanol, so I'm thinking the SeaFoam overdose must have really trashed them.
I'm told the new O-rings should be made of 'Vitol' in order to resist chemicals, which I'm now using.
With 20/20 hindsight, I should have just drained the old fuel, but I've used SeaFoam in bikes, tractors, vehicles for decades w/o problems.
Sure looks like I 'screwed-the-pooch' on this one. Can't think of any other explanation. Just dumb luck it happened in my garage & not 75 miles away.
Anyone else have this problem (and willing to admit to it) ?
Old 10-05-2022, 10:17 PM
RK4ME's Avatar
RK4ME
RK4ME is offline
Received 2,227 Likes on 1,389 Posts
In 2015 I bought a 1996 BMW R1100GS with 4K miles on it. When I removed the fuel pump from the gas tank to change the fuel filter, I noticed that the plastic fuel pump intake filter/sock had completely dissolved. The autopsy on the original fuel filter revealed nothing interesting. The bike ran just a bit rough but ran better after a couple tanks full of gas treated with fuel injector cleaner. BMW now sells small bottles of fuel injector cleaner but I use Techron in my bikes once a year, and treat the gas with StaBil when they're stored for winter.
Old 10-05-2022, 10:41 PM
2500hdon37s's Avatar
2500hdon37s
2500hdon37s is offline
Received 1,550 Likes on 668 Posts
I don’t think the O-ring damage was caused directly by the SeaFoam, but rather just exposed.
My theory is they were already damaged and dried out from the old ethanol gas, and ready to crumble. Then the SeaFoam took them the rest of the way out. And maybe is was a bit too much SeaFoam. Being a big believer in SeaFoam myself I’ll have to scrounge up some old O-rings to test it on.
Old 10-05-2022, 11:42 PM
NorthWestern's Avatar
NorthWestern
NorthWestern is online now
Received 5,628 Likes on 3,081 Posts
The old, rotten gas and age dries your petcock o-ring. I swear, it's the first one to go on old bikes.
I just had to change on on my 20 year old dirt bike that sat for 3 years.
Seafoam should not have been the culprit, and I too am a fan. I think you did just find with your method.
M Oclaf (10-06-2022)
Old 10-06-2022, 07:28 AM
Rick S's Avatar
Rick S
Rick S is offline
My 03 springer with 12 thousand miles started leaking from the top O ring. Yours was probably already dried out and the vibration and sea foam to some extent helped things along.
Old 10-06-2022, 07:31 AM
eighteight's Avatar
eighteight
eighteight is offline
Received 4,626 Likes on 2,681 Posts
The crud "helped" with the seal
The Seafoam dislodged the crud
2500hdon37s (10-06-2022)
Old 10-06-2022, 07:50 AM
Bingee's Avatar
Bingee
Bingee is offline
Allowing fuel to remain in the bike stored for years will cause considerable problems. No additives can correct that.
The fuel system components must be drained and flushed with solvents formulated to remove the deposits. Non-Metal parts
that have degraded need replacement.
fish425093
05-21-2021 09:40 AM
mgmmgm
05-14-2012 03:50 AM
RidemyEVO
EVO
19
05-08-2012 04:56 PM
trackadaptor
08-18-2010 02:31 PM
djamann
Exhaust System Topics
12-20-2007 05:19 AM
Quick Reply: Fuel Additives ?
