When to call it quits? When is enough, enough?
04-12-2024, 09:02 AM
The following 2 users liked this post by diablos:
04-12-2024, 09:35 AM
Quote:
Originally Posted by
CaffeineBuzz
nothing goes over your head, eh fella? your reflexes are too good, you would see it and catch it
if only there were a universally accepted sarcasm font
Thanks for your brilliant insight, a..h...
04-12-2024, 09:39 AM
It's too expensive to not get every drop.
I also look at this as the bottle will be cleaner during the recycling process if I get the last drop. Maybe!
Note: I do not like watching paint dry.
The following 3 users liked this post by Cosmic Razorback:
04-12-2024, 09:45 AM
I use a total loss technique. On the transmission, I carefully tip the oil container ( can't say can anymore) and let if flow gently.
I go for lunch and come back only to notice that I forgot to put the drain plug back in...
The following 4 users liked this post by ahhlou:
04-12-2024, 10:00 AM
davekp
i was clowning, about the oil change and you, no real harm meant, my friend
two wheels down, sir
04-12-2024, 11:28 AM
ahhlou
Done that to the primary to many times
04-12-2024, 11:41 AM
Bone Doc
I
It doesn't matter how many times you let it drip. The last drop always ends up in your shorts.
One of the reasons I wear black underwear. Actually the only clothes I ever wear are black.....except for my jeans. I have 25 mock turtleneck long tee shirts in the closet. Almost time to rotate to the short sleeves.
04-12-2024, 12:20 PM
Cosmic Razorback
My municipality considers empty oil containers non-recyclable and hazardous.
04-12-2024, 12:49 PM
barneyboy
Non-recyclable because they pose a risk, but safe for trash... Got it.
The following 3 users liked this post by BrandonSmith:
04-12-2024, 01:58 PM
RHPAW
FJB will decide when you've had enough oil.
FJB? Is that code for Let's go, Brandon (Smith)?
The following 2 users liked this post by Dynamick:
