Do Metzeler Tires Run a Little Skinnier...
Old 09-11-2007, 10:07 AM
Gamma742's Avatar
Gamma742
Gamma742 is offline
Default Do Metzeler Tires Run a Little Skinnier...
... than Dunlop tire? I am planning to jump to the Metzeler ME 880 Marathon Rear Tire size 170/60 VR-17from the stock which is a 170/70/VB-17. Someone told me that the ME 880 runs a bit narrower than the Dunlop. Anyone know if that's true?
Old 09-11-2007, 10:19 AM
dhampire's Avatar
dhampire
dhampire is offline
6th Gear
Default RE: Do Metzeler Tires Run a Little Skinnier...
http://www.us.metzelermoto.com/media...twin_07_lo.pdf
i found out that it's indeed true with my sportster rear tire. originals are 150/80/16 but this site advises 160/80/16 and that is the tire i am getting.
Old 09-11-2007, 11:21 AM
bandit2's Avatar
bandit2
bandit2 is offline
You will absolutley love these tires !!!!!!
Old 09-11-2007, 11:37 AM
cardboard's Avatar
cardboard
cardboard is offline
ORIGINAL: Gamma742
You have 160/70 17", the 170/60 17 is 1/4 inch wider. Go look at a dyna super glide screaming eagle. On my bike I could of gone with a 180/55 17. I got a dunlop tire that's a 160/70 17 with the tube and 900 miles on it for sale.
Old 09-11-2007, 12:13 PM
SoCal Harley's Avatar
SoCal Harley
SoCal Harley is offline
Changed from Dunlops to Metzelers and didn't notice a different. GREAT tires though......
Old 09-11-2007, 12:16 PM
Gamma742's Avatar
Gamma742
Gamma742 is offline
how much for your tire? Is it the stock tire?
Old 09-11-2007, 12:36 PM
Rebel Ryder's Avatar
Rebel Ryder
Rebel Ryder is offline
yes, IMO,metz are generally about 1cm smaller. on my wg I went from a stock 130 dun to 150 metz; its tight in that fender well but no rubbing!
Old 09-11-2007, 07:28 PM
wideglidebob's Avatar
wideglidebob
wideglidebob is offline
wish i would of known i have a 05 wideglide and went with the 150 rear metz, love them big difference but it does look alot skinner wish i would of gone to 160
Old 09-11-2007, 07:43 PM
Clammy's Avatar
Clammy
Clammy is offline
Received 1,790 Likes on 788 Posts
They shouldn't be any different. The sizing is an actual measurement. For example: a 150/80B16 means the tread width is 150mm, the sidewall height is 80% of the tread width (150 * .80 = 120mm) and the inner diameter is the rim diameter, in this case 16". All tires that are 150/80B16 will be the same size.
Now Metzeler (or any manufacturer for that matter) may recommend a different size than OEM, or may indicate that a larger tire can fit a stock rim, but that has nothing to do with the actual size of the tires themselves. For example, my stock front tire was a 80/90H21, but I put a 90/90H21 ME880 on the stock rim giving me a wider/taller tire on the front without having to modify anything else.
Cheers!
[sm=icon_rock.gif][sm=icon_rock.gif][sm=icon_rock.gif]
Old 09-12-2007, 05:12 AM
handyhoward's Avatar
handyhoward
handyhoward is offline
Metzler has had a size problem on some of their Brazilian made tires... as stated the size on the tire wall is the same for all mfgr's... however some of Metzlers tires say one size and actually measure out a size smaller.
Quick Reply: Do Metzeler Tires Run a Little Skinnier...
