belt guards
RE: belt guards
told by several indy shops they always take the bottom guard off / I already had and ask if it would hurt they said it was better than getting junk caught up in it hurting the belt makes sense .. also just because the moco put it there does not mean there is a good reason for it they are not all knowing.....
RE: belt guards
The bike I bought didn't have a lower belt guard on it. I have put over 4k on this summer without it. I plan on putting the chrome one on this winter. I think it's there for a reason, that's why I'm getting one. And it's more chrome... But either I have been lucky, or it doesn't do much.
RE: belt guards
I've ridden without either gaurd for over 3 years with no issues,including 1/2 mile on a dirt road to start and end each ride.In my opinion it looks much cleaner without them on.I imagine if the belt broke at speed I'd be wishing I left them on.
RE: belt guards
The top belt gaurd is not really too functional. It protects your passanger's foot/ankle. The lower belt gaurd however is functional. The lower protects your belt/sprocket from road debris. In all likelyhood, if you do get something in the belt and makes its way through it will be pulverized by the belt tension. However, you do run a greater risk of damaging the belt and sprocket teeth. Most riders go without incident but you have to ask yourself if the look is worth the potential cost of replacing a belt and/or sprocket.
RE: belt guards
I think you've got it backwardsTop gaurd protects you and passenger. For somthing to get into the bottom of the belt, it would have to travel from the top down at an angle, and not bounce off the belt, before geting sucked in, andhitting at the perfect 100,000,000 to 1 angle on the belt and pully at the same time. And feel under your gaurd anyway, its completly open
RE: belt guards
ORIGINAL: F.U.I.R.S.
RE: belt guards
took mine off day the bike came home. other than my passenger getting her foot caught in the belt/pulley and maiming her for life nothing bad has happened. j/k, looks alot cleaner without it, and every bit of weight taken off just made your bike quicker.
