Horrible Pivot in my 16" Apes!! HELP
Alright I put myh aes on back in march and have dealt with the pivot for almost 6 months now. HOW DO I FIX THIS!! It pivots at the clamp. I read where you can use a Bicycle tube, but i just tried it and it got worse. Please let me know how to fix this problem. Thanks guys.
RE: Horrible Pivot in my 16" Apes!! HELP
Can u make like u'r rowing a boat cursing down the road??? Man u need to fix that!!!! First time u grab for leverage or man handle a sitiuation your going down.....ahh hell u been riding that way for 6 months,,,sounds like u adjusted....
If is not in the bushing and it's really the bars moving in the clamp then do this....
Take a beer can, cut two "shims" out of it. Place the shim between the bars and the clamps. Tighten down...
I've been doing this for years, bikers have been doing this for years, motorcross guys have been doing this for years....
Works..and is cheap.
lp
lp
ORIGINAL: Jameson
lp,,,,I don't think they make beer can anymore,,,,think its all aluminum,,,how about a soup can???
whatever u do Jameson,,,make sure u can lift that bike wit out moving them bars.....
ORIGINAL: lp
lp
lp
ORIGINAL: Jameson
Thats what I'm talking about..aluminum shims... You can actually buy these at a motorcross shop, but why? If you have an empty beer or soda can use that...
lp
lp
ORIGINAL: YUCK
ORIGINAL: lp
lp
lp
ORIGINAL: Jameson
If you dont have internal wires, drill a 1/4 inch hole in both the top of the riser, and the top of the bar. Make sure it is exactly wher you want the bars to be as this will make it permanent. Than use a 1/4 inch bolt with the top cut off and insert it into bot the holes. It was the best thing I ever did to mine.
Don't know what kind of setup you have but I had to order a kit from wild1 that's chrome and goes inbetween the bars and the top riser clamps. Without them my bars would be loose as heck.
Look at yer bars and call them and ask about their kit if you want to spend the money.
