Gas Milage
Gas Milage
Hey guys,new to Harleys and own a 2003 Low rider with 300miles. It sat for 4 years. It used to cough unitl i installed the HD kit, jets, meter rod, idle screw. And performs well. It does not cough now but gas milage is only 20. I can't believe thats right. It also stalls coasting to a stop after a cruise. i have some thoughts but welocme experienced opions. I use 89-91 octane
Thnak you!
Thnak you!
RE: Gas Milage
Does the bike have a high flow filter and pipes?
May be too rich causing flooding and stall.
Option: Remove needle and replace original however, use two needle shims. You will have to readjust mixture.
RE: Gas Milage
Thanks, stock exhaust, stock filter. have K&N to install next week. 46 pilot jet 190 main. gas milage the same with stock needle, and jets. coughing is gone now. i am thinking enricher issue or possibly float or maybe sucking fuel thru vacumn for pump/ Any thoughts on common issues would be appreciated. I am going to do some test next week.
Just thought some one here may have had similiar problems
