Float level
Old Aug 14, 2014 | 08:14 PM
traildog's Avatar
traildog
Default Float level
If it's wrong, as in too high, could that have an effect on the way she runs?
Never had that with the YAMAKAHONDAZUKI.................
Old Aug 14, 2014 | 08:20 PM
texashillcountry's Avatar
texashillcountry
Dirt don't hurt
Then sell the Harley and buy that god awful thing back.
Old Aug 14, 2014 | 09:12 PM
Bumpandrun's Avatar
Bumpandrun
Low floAt level on race stuff is lean. High rich. But I don't think your at WOT enuff to worry unless your dumping gas
Old Aug 14, 2014 | 09:15 PM
traildog's Avatar
traildog
It was dumping gas....
Old Aug 15, 2014 | 06:37 AM
grbrown's Avatar
grbrown
That is more likely to be a dirty or defective float needle, which overfills the float chamber by not shutting the gas off. If you haven't serviced your carb in a long time, it is worth considering getting a rebuild kit, which will include all the perishable stuff such as gaskets and float needle.
Old Aug 15, 2014 | 06:40 AM
traildog's Avatar
traildog
Howdy stranger! I just installed a complete rebuild kit!
Old Aug 15, 2014 | 07:06 AM
grbrown's Avatar
grbrown
Red face
Ah! I just spent the last two weeks on your side of the Atlantic and am a bit jet lagged!
There is no good reason why the float level should have changed, but if either high or low then bike running will be affected. If gas is coming out of the overflow, then the float needle isn't shutting off the gas, as it should.
Old Aug 15, 2014 | 07:35 AM
traildog's Avatar
traildog
Or, I don't have the needle installed correctly.........which is probably more like it.......
Old Aug 15, 2014 | 07:40 AM
grbrown's Avatar
grbrown
Talking
Did you find a spare one left over, after refitting the carby?!
Old Aug 15, 2014 | 07:52 AM
WP50's Avatar
WP50
There is something of an art to setting the float level. Especially if someone is not accustomed to doing it. I have had the carb overflow a couple times and found a nick on the needles rubber tip both times. Took a small dowel rod shaped like the needle and some fine valve grinding compound and worked on the seat. Never did see a problem with the seat but figured it had to be something the second time. So far so good Knock on Wood
Dang Ok this was on a Keilin (sorry bout spelling) CV carb Ahh just remember to to ck the needle and seat real closely
Have a good 1 TD WP
