Voltage regulator making noise???
Old 01-23-2008, 07:22 PM
fasthorse's Avatar
fasthorse
fasthorse is offline
Default Voltage regulator making noise???
Battery is charged, unhooked from the charger/maintainer. But the voltage regulator is making this low growling noise still 45 mins after the charger is unhooked. What is that? Is this normal? Do I have a bad voltage regulator? Is it a recently charged battery thing?
Help please
Old 01-23-2008, 07:51 PM
fasthorse's Avatar
fasthorse
Default RE: Voltage regulator making noise???
[sm=hiya.gif]Anybody got any ideas?
Old 01-23-2008, 08:06 PM
csbreeze's Avatar
csbreeze
csbreeze is offline
This is not my specialty and I hope someone chims in to correctly if I am wrong. I think your Voltage regulator might be done for. If you hooked up your battery correctly and per a previous post I think your charger will not let it reverse on you I am almost certain your regulator is gone.
Tech guys chim in if I am right or wrong with my conclusion.
Old 01-23-2008, 08:25 PM
fasthorse's Avatar
fasthorse
Sorry for the dual posts, but the first post was when the battery was been charged.
Now it's doing the same low growling noise without the battery maintainer hooked up. At least 45 mins after been unhooked.
Could the battery be overcharged and the regulator is reducing the voltage?
Old 01-23-2008, 08:29 PM
csbreeze's Avatar
csbreeze
csbreeze is offline
Ok you really have me messed up now. Is the charger making the noise or the bike? I have had chargers that made a growl but not a bike. If the bike is making the noise take that charger off and carry it to a mechanic or at least talk to a mechanic. Your bike should not being doing that. I must have misunderstood your first post.
Old 01-23-2008, 08:32 PM
duke76's Avatar
duke76
duke76 is offline
try unhooking your battery for a few minutes, then reconnect and see if it still growls. Todd
Old 01-23-2008, 08:40 PM
BadBobOk's Avatar
BadBobOk
BadBobOk is offline
Does it growl like an African or European swallow?
Old 01-23-2008, 08:51 PM
aframe2's Avatar
aframe2
aframe2 is offline
There was a recall on some voltage regulators on some models. I can't remember the exact years, but I have an 06 RK Custom and the dealor replaced my voltage regulator per the recall. There was a post on the forum some time ago. If you do a search you might find it.
CTCNC's Avatar
CTCNC
CTCNC is offline
I have never had a voltage regulator growl.
get louder pipes
j/k
start the bike, at about 2000 rpm you should get 13.5 - 13.8 volts at your batttery with a tester. if you do, your regulator is doing its job
Old 01-23-2008, 09:08 PM
csbreeze's Avatar
csbreeze
csbreeze is offline
I have had chargers growl but not regulators. I am glad you guys are chimming in on this.
Quick Reply: Voltage regulator making noise???
