Tires?
Old Jan 18, 2006 | 11:11 PM
Axholio's Avatar
Axholio
Default Tires?
This question came up the other day and I thought I'd ask it here...
How many miles do you get out of a set of tires? I know there are many factors that contribute to tire wear, but just in general.
Thanks...
Mike
Old Jan 18, 2006 | 11:54 PM
DGlide04's Avatar
DGlide04
Default RE: Tires?
My experience with the stock Dunlop, fronts 12,000 or so, rears, maybe 9,000-10,000, like you said, depends on the riding style, speed, etc. Just replaced the rear on my '04 FXD with a Metzler 880, had 7,000 miles on it and there's still a bit of tread left.
Old Jan 19, 2006 | 12:03 AM
fxdxsteve's Avatar
fxdxsteve
Default RE: Tires?
with metezler's 8000-10000 rear
fronts dunlop 12000 metezler 24000 I'm on my second metz
Old Jan 19, 2006 | 12:50 AM
Inforit's Avatar
Inforit
Default RE: Tires?
10.5k on rear Dunlops probably had another 3k on them but decided to get it replaced over the winter.
Old Jan 19, 2006 | 01:18 PM
Screamer's Avatar
Screamer
Default RE: Tires?
About 10K.
Old Jan 19, 2006 | 02:28 PM
vernh59's Avatar
vernh59
Default RE: Tires?
Just changed my rear on my RK at 12,500. my last front went 22000. Not bad. Dunlop 402's, usually 1 up with tour pack and bags loaded.
Old Jan 19, 2006 | 02:56 PM
RudeDog's Avatar
RudeDog
Default RE: Tires?
I've used Avon Roadrunners ever since I found out just how slippery the (boycoted) Dunlops are that come with the bike . A word to the wise... If you ride enough use tires that'll get you out of wet road situations, i.e. Avon and Metzler. You'll get less miles before you have to change them but you'll get home safer when you get caught in the rain.
I get about 8,000 miles rear, 15,000 miles front on the Avons before I've got to change them. Hope this is helpful.
Old Jan 19, 2006 | 03:59 PM
95cdman's Avatar
95cdman
Default RE: Tires?
ORIGINAL: RudeDog
I 100% agree. Dunlop tires do suck. I run Avon Venom-R tires, Ill never go back to Dunlops. Superior wet and dry traction. I get about 10k out of mine. I always change the front and rear tires out together.
Old Jan 19, 2006 | 07:49 PM
bassrock's Avatar
bassrock
Default RE: Tires?
Have had no problems with my dunlops. 10500 on rear and will probably change it this spring. Front still looks good.
Old Jan 19, 2006 | 08:04 PM
Danester's Avatar
Danester
Default RE: Tires?
no probs either with my dunlops..11K on the rear- - had it changed because it was getting pretty thin - -almost see the air in it! The front looks like it can go another 5k easily ---
now it's the brakes next - -I think I'll be doing the rear first - -although the techs said I have 70% remaining - -(I have 11.5K miles now)
