Quick Question on "decel popping"
I see numerous posts refering too or asking about "popping". What is everyone referring too?
My Set-up.
2006 FLHXI
PCIII
V&H Classic Slip-ons
SE A/C
This is my first Fuel Injected bike, so I do not know if folks are talking about the old popping out the air cleaner, or back fire through exhaust.
When I engine brake or down shift, it sounds like the "cherry bomb" enhaust of yester-year, but I do not ever recall hearing popping out the Air cleaner. Do Fuel Injection bikes still pop out the AC or is this just a carb thing?When you are describing popping, is this exhaust backfire?
Just curious
My Set-up.
2006 FLHXI
PCIII
SE A/C
Just curious
RE: Quick Question on "decel popping"
Decel popping is exactly what it says. When you let off the gas, or decellerate, you get a "pop, pop, pop, etc" from the exhaust. Not as loud as a "backfire", but it is a backfire. It's really the first sign that something is wrong. Louder backfires, or worse yet, explosions in your air cleaner and other places, indicate serious problems with your bike and needs attention.
I think you're right on track. It is more of an exhaust backfire instead of anything through the air cleaner.
I like the referrence to "cherry bombs" on straight pipes. You are showing your age.
ORIGINAL: irishviking
"its normal" is what I got from the dealer after my PCIII install with dyno. I didnt get it from Jamie so I assume Iam f%$#&d.
ORIGINAL: DannyZ71
ORIGINAL: golfblues
It doesn't necessarily mean there is anything wrong. Short pipes, no baffles, etc. will always expose decell pops whilemuffled pipes will hide them. Just the way it is.
ORIGINAL: DannyZ71
I've always beentoldit was the first sign that a engine was running too lean. ???
ORIGINAL: DannyZ71
ORIGINAL: golfblues
ORIGINAL: DannyZ71
ORIGINAL: golfblues
But aren't they all running lean from the factory to pass emmissions? Will it hurt? I don't think so at the factory settings. The'll just run hotter, pop & spita bit.
ORIGINAL: DannyZ71
ORIGINAL: golfblues
ORIGINAL: DannyZ71
