Synthetic Oil or Not?
Old 10-28-2008, 12:24 PM
tydan's Avatar
tydan
tydan is offline
6th Gear
Default Synthetic Oil or Not?
I'm getting mixed answers on wether or not to put synthetic or stick to regular Harley oil for my bike. I'm wondering what you guys use and think?
Old 10-28-2008, 12:50 PM
BCguy's Avatar
BCguy
BCguy is offline
There is about a million posts on this subject so read till your eyes fall out then put in synth (whatever brand turns your crank). Synthetic is better in all ways than dino oil so to me it's a no brainer but it's your bike so do what you like.
Old 10-28-2008, 01:51 PM
GT_RoadGlide's Avatar
GT_RoadGlide
GT_RoadGlide is offline
Syn "motorcycle" is better. The above post is 100% correct.
Old 10-28-2008, 01:53 PM
oldgeezer's Avatar
oldgeezer
oldgeezer is offline
I'd use either synthetic or dino or synthetic blend. Hope that helps.
skidder's Avatar
skidder
skidder is offline
What about during break-in?
Old 10-28-2008, 02:33 PM
hardluk1's Avatar
hardluk1
hardluk1 is offline
oldgeezer, Old hippes, never could make up there minds. hehehe
Old 10-28-2008, 02:43 PM
cadman311's Avatar
cadman311
cadman311 is offline
I change my oil every other month in the summer time. I like synthetic oil because of the heat it's not going to brake down like dino oil will. Summer we put alot of miles on the bikes. I will change other people oil with dino oil it is so burn when it comes out. The synthetic oil will come out cleaner and not burn.
Old 10-28-2008, 02:45 PM
bullseye's Avatar
bullseye
bullseye is offline
The above posts claiming synthetic is better are correct. Your engine will run cooler, longer and with fewer repairs. There are many on this forum than may not agree with that but those are the facts. You can run synthetic from day 1 in all 3 holes. I also recommend 75 - 90 synthetic gear oil in the tranny. Amsiol and Mobil 1 are my picks for the top 2 in that order.
Old 10-28-2008, 02:55 PM
cadman311's Avatar
cadman311
The other day a new ride was using mobil 1 oil and want to know why his bike knocking so bad. It's your choice. But I do like the gear oil in the trans.
Old 10-28-2008, 03:11 PM
barjbar's Avatar
barjbar
barjbar is offline
I use synthetic in all 3 holes. Wait till the 1,000 mile oil change before switching.
The technical advantages of synthetic motor oils include:[citation needed]
  • Measurably better low and high temperature viscosity performance
  • Better chemical & shear stability
  • Decreased evaporative loss
  • Resistance to oxidation, thermal breakdown and oil sludge problems
  • Extended drain intervals with the environmental benefit of less oil waste.
  • Improved fuel economy in certain engine configurations.
  • Better lubrication on cold starts
Quick Reply: Synthetic Oil or Not?
