gear driven cams
have an 02 roadking(53,000 miles)cam chain and adj.replc at 35,000 , want to install gear drive cams,was told by a guy not to do it, somthing about weak/loose end play allowing the gears to bind up....any truth to this ???
thanks
revhappy
thanks
revhappy
Why you so happy?
You need to check the crank runout. I went gear drive on my 05 a couple of years ago after finding pieces of tensioner material in the oil filter. I had less than 15K miles on it at the time.
I have no regrets and would do it again.
RKRon gave ya the answer. IF your crank run out is good, NO PROBS. Some ppl think they are a li'l noisy.
BUT not as noisy as when the chain tensioner takes a chit, and then the 'dead silence' as you coast to a stop.
gear drive cam's are the only way to go. i love them no worry no problem's they are worth every cent.
