Question: 5-Gallon Portable Air Tank
1 Post
Does anyone keep a 5-gallon portable air tank in their garage for adding air to their tires? I've got a small 12 volt compressor that will do that job, but it's slow and noisy. I want something that is quicker and more convenient. Could I fill up a portable air tank with the compressor I have?
Thanks.
Thanks.
I have a Air Tank that I carry around......I also have a Big compressor at home to fill up my portable.....
The 12 volt should fill the tank to the 12 volts pressure rating weather it be 60 or 100lbs.All depends I guess....
1 Post
It just seems that it would be much quicker and more convenient to grab the small air tank, press the nozzle to the tire valve, and be finished in about 5 to 7 seconds. No noisy compressor running and no exhaust fumes from the vehicle running.
A tank works fine as long as the pressure is fairly high (full). It's when the pressure in the tank falls below the pressure you need that it doesn't work too well. That happened pretty quickly in my experience. YMMV
I have a 5 gallon tank from Sears, max air pressure of 135 psi. I fill it at the gas station, and it works just fine for the touch-up jobs. However, as someone mentioned as the pressure drops, if the tank pressure is only a bit above the tire pressure, then it may not fill the tire. If fact, the tire could backfill the tank. So I only let the tank pressure drop to 80 psi before I refill the tank.
1 Post
Also, since motorcycle tires are smaller than car tires (in volume) I assume that the tank would top off more motorcycle tires than car tires?
