Detachable Bracket Hardware
If you want to make an item detachable, and you buy the correct detachable bracket, is there any additional hardware you need to buy to modify your bike to install them? For example, if you are adding a Tour-pak, and you buy the detachable bracket for it, will it just mount to your bike. Or, do you have to buy some type of bracket to mount to your bike as well.
I am assuming it is the same way with saddlebags as well. I would think you could just buy the detachable bracket for the item and install it. But knowing HD, I'm guessing there is some kit I need to buy to install to the bike first. If so, do I need to do that to every detachable bracket I buy?
Please tel me this isn't something I would need to do more than once.
Not sure what kind of bike or year you have. On the 09 you can buy 4 point and 2 point docking hardware and it is a snap to install yourself. I have the 4 point which can accommodate a tour pack or a sissy bar. A luggage rack will also work at the same time with a sissy bar. The two point might only allow a sissy bar but I'm not sure.
I believe you can also install the docking hardware for either solo or 2-up riding. Solo would move a tour pack to directly behind the rider (with no room for a passenger) as opposed to being further back.
Not sure how other year hardware works but might be comparable.
I have an 08 Fatboy. I'm just trying to figure out which hardware kit I need for to cover both the saddle bags and a detachable two-up tour-pak. The bags may be the EZ Brackets...I'm not sure yet.
My posts would pertain to touring models. Too much probably has changed since 2001 when I sold my FatBoy to know much about the Softail Detachable hardware. Sorry
