Belt Tension Adjustment Question
I'm new to belt drives, so I haven't really developed a feel for these new-fangled things. It's a new FXD with about 700 miles on it, and I intend to do the 1000 mile service myself. Got the shop manual. When I measure my belt deflection with the HD deflection tool I'm getting about twice the recommended deflection for the 10 lbs of sideload....I know how to move the rear axle back to increase the tension, but can anybody give me an idea of how sensitive that adjustment is? In other words, will I probably end up turning each of the adjustment bolts (equally, of course) a fraction of a turn, or quite a bit more?
The adjuster is a fine thread pattern, you will likely end up with a couple of full turns. When I adjust mine I usually do one full turn and measure, repeat if needed.
Is belt wear and stretch pretty much a continual process....or is the initial adjustment the largest?
When I have to adjust the back wheel I use two wrenches one on each side. Put them at the same angle and adjust each the same amount of turns. I do half turns until adjust is right just be sure to count and keep the wrenches the same. The easy way to get close adjustment on the belt is to twist it right behind the primeary. If it goes half way around or close to it then you are close. Hope this helps. Oh do not over think this it really is not very hard.
I don't use the 'special tool' Harley recommends. 10lbs. aint that much. Push on a bathroom scale if you wanna verify that. The manual also gives instructions on how to create a measuring tool for the length out from the swing arm pivot bolt, that was easy to make. The first time I adjusted mine I simply counted the threads and moved each one an equal amount. THEN I made the measuring tool and it was dead on.
As stated previously, over thinking this process will make it more dificult. Once you have done the adjustment, watch the wear on the belt and sprockets and listen for any odd sounds, this will 'tell' you if you mucked it up.
I don't know about a FXD, but the RK manual says to measure the belt deflection with the rear wheel off the ground and no pressure on the shocks (on a lift). I know the RK and FXD frames are different, but I'd make sure just in case. You definitely don't want to overtighten the belt.
