New 2010 Ultra - For 8 miles
Good advice.
The dealer is just off the highway so I really had no choice but to come home that way. I wanted to leave this bike stock (so it would be unique to others) but I may need to change that thought process.
Any other comments would be great - thanks guys !
I thought that the "parade mode" would kick in at lights or when the bike is stopped...but as soon as throttle is engaged it would revert back to normal operating.
could be wrong about that but that's what the sales guy told me about them when I asked....
The same thing happened to me when I bought my 09 Heritage. I was sitting at a light and all of a sudden the bike starts shaking and the engine is missing and sounds like I fouled a plug. A quick twist of the throttle and all was well. Got home and looked in the owners manual and discovered the bike had this heat control system. Basically, when the heads reach a certain temp the rear cylinder shuts down both spark and fuel. When you twist the throttle it comes back on line. I called the dealer and talked to the service mgr. because here in Las Vegas it is hot and it comes on quite often. He said not to worry won't hurt the engine. He also said that if I wanted they could disable it. But yes, the first time was scary, I thought wtf was wrong with the bike. So, you can live with it or have the dealer disable it.
Been lurking here for awhile and need some help - Please ?
Picked up a 2010 Ultra yesterday. I left the dealer in and entered heavy traffic for the next 8 miles, never left second gear. At the 8 mile mark the bike sounded like it was rapping and banging so bad that I shut it down and pulled into the break down lane. This was no normal Harley sound it was NASTY!
Called the dealer to have him pick it up and find out what was wrong. While I was waiting I started the bike and .......NO bad sounds. Go figure. Dealer said I may have rolled the throttle into "parade mode" New to me I didn't know I could do that on a 2010. As a matter of fact the salesman told me that it happens automatically at a certain temp.
So finally heres the question part:
Anyone else's bike make these types of noises?
You can not hear the noise over the internet. It only has 8 miles on it
If I or it went into parade mode is the sound normal?
Take the bike to the dealer to get aquainted or ask one of the local hog members in your chapter.
What damage may have occured?
It only has 8 miles on it!
What do you think the dealer will say?
WTF, Call or go visit the dealer how should we know. The bike only has 8 miles on it.
Thanks in advance.
Thanks in advance.
Sorry, but this is a real dumb post for the sewing circle. To me the proble is a paraniod rider that depends on the internet to much.
I wouldn't think a bike would go into "parade mode" in 70 deg. weather. I guess those new ones really do run hot as hell. Of course stop and go traffic is rough on a stock Harley. Most the time I see guys taking the shoulder instead of just sitting because of the overheating problem being air cooled. As far as leaving it bone stock, I wouldn't. You really need to richen up the fuel to cool that thing off or you'll probably regret it. Not so bad in cool weather but in the heat it's brutal. Doing a stage one would help a lot.
More money, but it's just the way things are with a Harley right now.
Eitms
The new engine runs hotter until broken in, tight tolerance.
The EITMS, Engine Idle Temperature Managment System shuts down the rear cylinder when hot and pumps a little extra fuel for cooling. Kicks in when front cylinder reaches 285 Deg. F
Most times not set at dealership, lucky for you yours was! Keeps engine from self destructing from the heat! see operators manual on how to set!
Will kick off and return to normal if you blip the throttle, just kicks in at idle speed.
The new 2010 EPA Air Standards got even tougher, the bikes were already leaned out and hot from lean AFR and EPA Cams. In 2010 the touring Harley got the Catalytic Converter in the headpipe. Even hotter.
Dump the cat, get a header pipe without a catalytic converter, slipon free flowing mufflers.
Parade Fan
Larger oil Cooler, with fan! Jagg 10 row or UltraCool is a good one.
Tune, richin up AFR
We never had to baby a Harley on break in before but I would try to stay out of traffic on hot days until broke in. At 1000 mile service go with a good synthetic oil. They don't burn off until around 300 deg.
You just got hit with the Harley Tax
They will be a rash of heat complaints from the 2010 baggers this summer, they are running much to hot now that they are being built more for the EPA.
Parade Fan
Tune, richin up AFR
It does say that it isn't activated as standard, but since I live in the cold uk, it probably isn't needed. If you buy a bike from somewhere hot, they may engage the temperature management as a matter of course.
