Do you use wrong oil?
I am not asking about manufacturer, only weight. It seems like 95% use 20W50 oil when manual says to use streight 60.
Are you using recommended weight?
I just begun using right weight.
From 2000 FLT manufacturers manual:
10W40 below 40F
20W50 above 40F
50 above 60F
60 above 80F
10W40 below 40F
20W50 above 40F
50 above 60F
60 above 80F
i use 20w50, mainly because m climate doesnt call for the heavy weight, and HD is the only place to get 60w and i aint spending $34.99 a quart X3 every 1000miles on oil when i can go to wal-mart n get the castrol motorcycle oil for $4 a quart
Received 4,385 Likes
Just checked both of my manuals, SAE 60 is recommended for conditions when the LOWEST ambient temperature is above 80* F (27* C). If the temp drops down to mid forties or fifties with that oil in the engine I would be concerned about the oil going to where it's needed on startups.
I use 20W50 all season because it's suited for the widest range of temps. Another reason is I buy the same weight by the case and use it in both my Harley and BMW.
10W40 below 40F
20W50 above 40F
50 above 60F
60 above 80F
10W40 below 40F
20W50 above 40F
50 above 60F
60 above 80F
20-50 syn is recommended for the temperature range I ride in. If they made 20-60 syn in my brand I would run it. If they gave away free oil in my brand and the weight I need I would smile when I changed the oil. Oil change in my bike is more expensive then my truck or jeep due to the cost of a chrome filter plus the brand. No----I don't run HD brand oil. Low bid contractor oil.
