Leaking neck bearings
Old 07-24-2010, 02:09 AM
speedracr1972's Avatar
speedracr1972
speedracr1972 is offline
6th Gear
Question Leaking neck bearings
I have a 09 Night Train that i bought in dec. 09. I enjoy riding it daily but the hotter it gets the more the grease from the neck bearings leak out and all over me. The Harley dealer where i bought it says its normal and i have to deal with it. I have been thinking about buying some Hi-Temp grease and just pumping it full till all the old grease is gone but i dont want to mess anything up by mixing the two together. Any suggestions?
Old 07-24-2010, 02:15 AM
phrogflyer's Avatar
phrogflyer
phrogflyer is offline
normal. i'm sure it's not all over you. but if you say so. was the bike recently serviced? probably so if it's blowback from the wind. put some miles on it and it will eventually quit blowing back. nothing wrong with it.
Old 07-24-2010, 05:07 AM
todd-67's Avatar
todd-67
todd-67 is offline
Received 3,405 Likes on 1,593 Posts
When they service them they often pump the neck full. In the heat the grease comes out. I am with you that it is a pita but it is also pretty normal.
Old 07-24-2010, 05:33 AM
05Fatty's Avatar
05Fatty
05Fatty is offline
I had the same thing, just wipe the excess off with a paper towel or something, it gets a lot better after that.
Old 07-24-2010, 06:30 AM
pavin's Avatar
pavin
pavin is offline
Thats the crap grease harley recemends, my indy recently tightend my stereing head and i got grease dripping down my fender, told my indy no more ill grease it myself. took me 30 mins to clean up around the head tube.
Old 07-24-2010, 07:44 AM
1flhtk4me's Avatar
1flhtk4me
1flhtk4me is offline
If the neck has been greased to capacity,the grease will purge out from the bottom.
Take a rag and wipe off the grease from the lower tree.
Old 07-24-2010, 08:30 AM
Tom84FXST's Avatar
Tom84FXST
Tom84FXST is offline
Received 18,319 Likes on 5,423 Posts
Grease fitting was added to combat the effects of pressure washers...older bikes didn't have them and would last for decades without added grease.
haak30
04-19-2012 05:45 PM
gilmour68
08-12-2010 04:58 AM
ajay450
03-12-2009 08:43 AM
Master of Mayhem
03-02-2009 07:32 AM
TheShrink
09-15-2008 06:50 PM
Quick Reply: Leaking neck bearings
