Steering head bearings
Old Aug 5, 2009 | 10:59 PM
gilmour68's Avatar
gilmour68
Default Steering head bearings
I'm preparing to do the 10k maintenance on my XL. Nothing on the maintenance schedule looks very daunting, but I really want to grease the steering head bearings.
The shop manual doesn't explain it very well, it just lists the lube to use (HD brand of course), but it gives no step by step instructions on how to "open up" the steering head and perform the process.
So I'll ask the forum members. How is this best accomplished??
Old Aug 5, 2009 | 11:37 PM
drum412's Avatar
drum412
I don't know what the recomondations were for your bike. But the maintnance schedule for my year simply required lubrication of the bearings at 10000 miles without disassembly. On my bike it's got a zirk grease fitting, and simply pump new grease in, and i'll ussually do it long enough that I see the new grease pushing out after the majority of old grease is pushed out first. I got 80k miles on my bike now and never had to take the stearing stem apart.
Old Aug 5, 2009 | 11:47 PM
gilmour68's Avatar
gilmour68
I'll have to look for a grease fitting. Seems like it would be odd to have to pull the front end apart to grease it. Guess it's time to look a little closer at the manual.
Old Aug 6, 2009 | 12:32 AM
bwana1's Avatar
bwana1
First of all, sportsters do not have a zirk/grease fitting in the neck.
About 10 - 15 years ago, HD found some extra zirk fittings and decided to install them in all big twins to justify a $1000 per bike increase.
The bearings in the neck are tapered timkin bearings identicle to bearings in the hubs of all trailers. The bearings are packed (not the neck) prior to assembly just like on a trailer. Pumping the neck full of grease is a waste of good grease. Probably why HD doesn't do it at the factory along with the fact that it makes a mess on the fins of the front cylinder. If you have ever repacked a bearing in the palm of your hand, forcing the old grease out as the new grease goes in, you will understand that packing that neck does not repack the bearing.
let the flaming...
check 6
Bwana
Old Aug 6, 2009 | 01:04 AM
HarleyScuba's Avatar
HarleyScuba
Very interesting. I've seen the grease drip out of bikes' necks on the show-room floor. It does melt and make a mess. Maybe it's the melting grease that lubes the outside of the bottom bearing. No idea about the top one.
Old Aug 6, 2009 | 06:29 AM
drum412's Avatar
drum412
well my sportster does have zirk fittings and on both neck and also swingarm, manual shows them as well. Although my bikes a 94, no clue how the newer bikes are set up.
Old Aug 6, 2009 | 07:16 AM
FastHoss's Avatar
FastHoss
They are sealed bearings,no lube required.
Old Aug 6, 2009 | 07:37 AM
xFreebirdx's Avatar
xFreebirdx
My 96 has them as well on the neck and swingarm.
Old Aug 6, 2009 | 07:42 AM
xFreebirdx's Avatar
xFreebirdx
Old Aug 6, 2009 | 07:44 AM
gilmour68's Avatar
gilmour68
According to the Maintenance Schedule in the manual, the 10k service suggests to "adjust and lubricate" the steering head bearings.
The Clymer manual I have doesn't mention the steering head bearing lubrication process either. If it does I haven't yet seen it. The section on the front suspension and steering describes the removal of the forks and triple trees. Seems a bit excessive to lube the bearings.
There's no mention about this in the "lubrication" section of the routine maintenance section either.
Seems a bit contradictory...
