Dual source heated vest
Turns out I'm the one that's missing something. You are correct. The 3-setting controller works with the bike battery harness, so I could have saved myself $60. The "**** controller" is heavier guage wires and seems to be a little more robust than the controller that came with the vest, so I guess now I will have a spare controller. I tested both controllers out by connecting them up to the vest and the bike battery harness and all systems seem to work fine. As for the portable battery, I did receive a "new" battery recently (although it looks suspiciously like the same one I returned), but guess what ... it still doesn't work with the vest or either of the controllers. Like my tag-line says, I'm not a complete idiot, but this vest/battery thing sure is making me feel like one.......
That sucks about the vest portable battery. I have the same vest and have only used it on the bike connected to the bike battery. The vest gets hot on high! I was thinking of getting the portable battery but after hearing all the problems you and others have had, I think I'll pass.
I'm hot, but not bothered (any more)
Since I sort of hi-jacked this thread, I thought I might as well go all the way and finish my story. After obtaining a THIRD battery for my dual-source heated vest, and after some expert hand-holding provided by Gerbing's, I am now cozy warm in my dual-source heated vest with working portable battery. It seems unusual that I would have gotten two, count 'em two, defective batteries, but that appears to be exactly what happened in my case. My apologies to the OP for my ranting and raving, and thanks for letting me borrow your thread to let off some steam. Anyway, bring on the chilly weather 'cause I gotta test this thing out on an actual ride.
Gerbing's just walked me thru the process of testing the battery. Had me connect it directly to the vest without the controller to see if the battery or the controller was the problem. They were very helpful but I only contacted them for information so I wasn't expecting Gerbing's to replace or repair anything. The technology for these vests has changed recently (from old style wiring to micro-wire) and the battery packs have been changed/upgraded as a result. It appears that the wiring connections have changed also, from battery tender type wiring to coax connections, so there are a lot of changes going on that could potentially cause issues. I have no idea if all this is going from better-to-worse or vice-versa. This is my first experience with heated apparel so I don't have any clue what's good, fair or unacceptable performance. I just know that my vest works now and I'm happy about that.
