Wheel bearing removal
Old Dec 31, 2010 | 09:42 AM
Jack Straw's Avatar
Jack Straw
Originally Posted by PineyRider
You never re-use old bearings. If you weld in a washer (actually I have a piece of 1" bar stock that I cut 1/4" thick pieces from), you just use a long punch. I have an old crappy Tiawan 1/2" extension I use as a punch. Those bearings pop right out of the soft aluminum wheel. When you press in the new bearings make sure you press them by the outer race of the bearing or you'll destroy the new bearing.
And for that matter if you don't have a press just get a piece of threaded rod with a couple of nuts and you can pull the bearings into the wheel. The whole process is really much easier to do than to explain in writing
Ohhhhh....I see (said the blind man). I get it. Wasn't sure what you were talking about at first.
Old Dec 31, 2010 | 10:21 AM
krusty1's Avatar
krusty1
People tend to do well what they do often. You aren't going to be changing out wheel bearings all the time (unless you're overtorquing the damn things)....so it might be better to take the wheel (and replacement bearings) a reputable wheel and driveline shop..won't cost much..they'll get it out and a new one pressed in without damage. They may even have some useful suggestions about a more durable high quality replacement bearing (or some comments about what caused the failure.....like improper torque wrench application or seal failure).
Old Dec 31, 2010 | 03:17 PM
brihvac's Avatar
brihvac
Replying to an old thread
Old Dec 31, 2010 | 06:18 PM
trozenhorse's Avatar
trozenhorse
so while we are all on this topic, what are the best bearings to put in? i hear a lot about the "all ***** "wheel, the dealer on montreal charges $40 per bearing thats $160 for all 4, which is crazy and have been reading some bad stories about wheel bearings, id like to hear what you all recommend, they are out there at all different prices and i am in the market....thanks Everyone and happy new year!
Old Dec 31, 2010 | 06:19 PM
RidemyEVO's Avatar
RidemyEVO
Timken says it all.
Old Dec 31, 2010 | 09:00 PM
krusty1's Avatar
krusty1
Ya know...I usually try to check the OP's thread date....but sometimes somebody posts something on an old thread and I just slip into the line of responses.
Old Sep 12, 2011 | 07:05 AM
collin's Avatar
collin
Auto Zone loans the blind bearing puller, just leave a deposit, mine was 170, and they refund it when it's returned. It works great. Other auto stores might have the same service. I grease the new bearing and put them in the freezer and use a old bearing with the center removed to tap them in. They also loan the 36 mm socket for the rear wheel.
Old Apr 23, 2012 | 07:59 PM
outfront's Avatar
outfront
2nd Gear
Thumbs down front wjheel bearing removal
typical MOCO move, make something five times harder to do than need be. No wonder Victory's are taking off!!!!!!!!!!!!!!!
Try changin the rear belt on a harley in an hour
Freaking engineers
Old Apr 24, 2012 | 07:50 PM
outfront's Avatar
outfront
2nd Gear
Took the torch to the inner race, dropped the ***** out then pulled the outer with a lady slipper.
Had previousley put the new bearing in the freezer so between the minor heat I put to the wheel torching out the old bearing and freezing the new bearing it dropped right in with little effort.
Was hoping I had put the torch away when I gave up wrenching heavy equipment
beammeup
Wheels/Tires
Aug 16, 2015 04:44 PM
Ultra Pearl
Jul 13, 2014 03:36 PM
hardheaded
Feb 27, 2013 07:34 PM
roofer
Jul 26, 2010 08:45 AM
bigdog1949
Wheels/Tires
Jan 18, 2010 11:40 AM
