Storing bike in unheated garage....
I respectfully disagree with the logic of running it once a month. Winterize it well and leave it alone till spring. JMO
sterrac (06-13-2019)
If your concerned about moisture rising from the cement floor put a plastic 'panel' or tiles or any other barrier down to block moisture from rising and put your bike on that.
Covered the bike with a plain bedsheet (so it will breathe) and your ride should be good for that long winter nap.....
PS I agree with Cheater about not starting it monthly. All that will do is create moisture in the oil pan or oil tank and you don't want that.....
A unheated garage is fine, use battery tender, stabil and do not run unless you can ride it enough to get all 3 holes up to a good operating temp to burn off internal moisture you'll get just starting engine!
© 1999-2010
Total Motorcycle
You are here: Home --- Motorcycle Maintenance Guide --- Winter Storage
Winter Storage
Total Motorcycle's 10 Step Guide to Winterizing your motorcycle
1 Location - where are you going to put it?
One solution may be to ask your dealer if he offers a storage program. This is ideal because he will often prep, store, and have the bike ready to ride when you are ready again. If you decide to store it yourself, you will need a place that is dry and out of harm's way.
When possible. Chose a location away from windows. The ultraviolet light can fade paint and plastic parts. Direct sunlight can raise the ambient temperature of the storage area which will promote condensation when the sun goes down, so cover plain glass with some sort of opaque material. Also, cover your bike with a specially designed bike cover not a sheet or a tarp. Why? Because a sheet absorbs moisture and hold it against metal surfaces and then rust forms. Also, damp fabric will breed mildew and this may attack the seat material. A tarp prevents moisture from getting in but it also prevents it from getting out. Moisture trapped will condense on the bike and then the rust monster is back!
A specially designed motorcycle cover is made of a mildew resistant material. The material is slightly porous, so it can breathe.
2. Change The Oil
Tip: Just like cars a colder winter grade oil will allow your bike to start easier in colder weather. If your motorcycle runs ok with a cold winter grade oil (5w30) then changing the oil to this grade will help startup and running in spring.
Even if the oil is not due for a change, byproducts of combustion produce acids in the oil which will harm the inner metal surfaces. Warm the engine to its normal operating temperature, as warm oil drains much faster and more completely.
While you are at it, why not change the filter too? Add fresh motorcycle grade oil. Remember to dispose of the drained oil and old filter in a responsible manner. What to do with the old oil? Recycle it. Most stores you have purchased the oil from will take it back free of change to be recycled.
3. Add Fuel Stabilizer And Drain Carbs
Tip: You only need to drain the carbs if your motorcycle will be stored more than 4 months. Otherwise just add fuel stabilizer to the gas tank, run the bike for 10 minutes so it mixes and gets into the carbs.
Fill the tank with fresh fuel, but do not overfill. The correct level is when the fuel just touches the bottom of the filler neck. This gives enough room for the fuel to expand without overflowing the tank when temperature rises.
Shut off the fuel petcock and drain the carburetors and the fuel lines. Add winterizing fuel conditioner to prevent the fuel from going stale, and help prevent moisture accumulation. Stale fuel occurs when aromatics (the lighter additives) evaporate leaving a thicker, sour smelling liquid. If left long enough, it will turn into a gum, plugging the jets and passages inside your carbs!
4. Lube the cylinder(s)
Tip: You only need to do this if your motorcycle will be stored a very long time (6 months or more)
Because gasoline is an excellent solvent and the oil scraper ring has done its job, most of the oil from the cylinder walls have been removed since the last time the engine was run. If the cylinder wall is left unprotected for a long period of time, it will rust and cause premature piston and ring wear.
Remove the spark plugs and pour a tablespoon (5 cc) of clean engine oil or spray fogging oil into each cylinder. Be sure to switch off the fuel before you crank the engine or else you may refill the drained carbs! Also, ground the ignition leads to prevent sparks igniting any fuel residue. Turn the engine over several revolutions to spread the oil around and then reinstall the plugs. Refitting the plugs before cranking the engine could result in a hydraulic lock if too much oil was used in the cylinder.
5. Battery Storage
The battery must be removed from the motorcycle when it is in storage. Motorcycles often have a small current drain even when the ignition is switched off (dark current), and a discharged battery will sulfate and no longer be able to sustain a charge.
A conventional battery should be checked for electrolyte level. Add distilled water to any of the cells that are low and then charge the battery.
Battery charging should be performed at least every two weeks using a charger that has an output of 10% of the battery ampere hour rating. For example if the battery has an AH rating of 12 (e.g. 12N12A-4A-1 where the 12A is 12 amp hours), then the charge rate of that battery should not exceed 1.2 amps. A higher charge will cause the battery to overheat. Charge the battery away from open flame or sparks as the gas (hydrogen) given off a battery can be explosive. Elevate the battery and keep it from freezing. Exercise the proper caution appropriate to caustic substances.
6. Surface Preparation
Waxing and polishing the motorcycle might seem like a waste of time since you are putting it away and no one will see it. But applying wax is a very important part of storing a motorcycle.Wax will act as a barrier against rust and moisture.
Don't forget to spray any other metal surfaces (such as the frame or engine) will a very light spray of WD-40. This will keep these areas shiny and protect from corrosion as well.
7. Exhaust and Mufflers
Exhausts/Mufflers are known to rust fast when they are not used. So making sure they are properly stored for the winter on your bike will save them from an early rusty death. Spray a light oil (such as WD40) into the muffler ends and drain holes. Lightly stick a plastic bag (shopping bag is fine) into the end of each muffler hole (to keep moisture from getting inside the exhaust). Then cover each muffler with another plastic bag to keep outside moisture off.
8. Tires
Check both front and rear tires with your air pressure gauge. Make sure each tire is properly inflated to the maximum recommend pressure. As it gets colder, air condenses in your tire so it is important to pump them up as to keep your tires healthy. Rubber is a flexible material and does not like to freeze (it cracks when it freezes). Placing 1/4"-1/2" piece of cardboard or wood board under each tire will help keep the rubber raised up from a freezing floor.
DO NOT use a tire dressing on tires (such as Armor-All or tire cleaning foam) as this will make the tires hard and slippery.
9. Service all fluids
If the brake or clutch fluids haven't been changed in the last two years or 18,000 km (11,000 miles), do it now. The fluids used In these system are "hygroscopic" which means that they absorb moisture. The contaminated fluid will cause corrosion inside the systems which may give problems when the motorcycle is used next spring. Be sure to use the correct fluids and note the warnings and instructions in the service manual. If you don't have the experience to service these systems, contact your dealer, he will be happy to assist you.
If your motorcycle is liquid cooled, the coolant requires changing every two years or 24,000 kms (15,000 miles). Make sure that the engine is cool enough to rest your hand on it before draining the system and please dispose of the coolant responsibly. Coolant/antifreeze is available from your dealer and has been developed to provide the correct protection for your motorcycle engine. Mixed 50/50 with distilled water will ensure a clean system for the next two years or 24,000 kms (15,000 miles).
10. Cover it.
Now you can cover the bike with the cycle cover and look forward to the first warm day of spring.
Back On The Road
Before you head out onto the highway, there are a couple of things to do. First, remove the cover and put it where you can find it again. Talking of finding things, locate the (charged) battery and reinstall it connecting the positive (+) cable (red) before the (-) negative and covering the terminals with the plastic covers. Recheck all fluid levels and turn on the fuel. Check for anything wrong on the motorcycle (cracked tires, broken parts/plastic, leaking oil). Set the tire pressures back to riding specs and you are ready to fire up.
As you don your riding gear, remember that your riding skills will be a little rusty and the road surfaces will have changed a bit since the last ride, so go carefully. Sand/salt deposits on the edge of the road and especially at corners may be hazardous.
© 1999-2010
Total Motorcycle
Winter Storage
2. Change The Oil
5. Battery Storage
8. Tires
10. Cover it.
Back On The Road
Maybe in Tenn. I don't know where the OP lives. I relate
to my experience in Buffalo, NY I've seen water dripping
in puddles on the floor.
As I said above, you live in Virginia, you have different
weather, and your garage may be insulated.
Yes, you too are located where the weather is different.
Many times questions are asked that have different answers
for different places. The OP doesn't say where he's located.
Oil & filter change, Sta-bil, fill the tank, wash, tender and tires off concrete. That's what I do. I also disagree with the starting it during winter. You'll put moisture into the exhaust and engine oil.
It is OK, however to go out into the garage in January and February, sit on the bike and make "vrooom vrooom" noises
My bikes are always in a non heated garage and they are fine. I have them under a cheap thin cover and on battery tenders, but that's it. I pull them out in the spring, fill the tires back up to normal and give them a nice wipe down-good to go since I service them before storage.
Electronics
A lot of the new baggers are loaded up with electronics, in a cold damp garage they could be effected. Pull the bike up on some rubber mat or heavy plastic if on concrete and put a float charger on it to keep the battery charged.
I put a cover on mine and then put a 100W light under the cover on some kind of fireproof material, that should be enough to keep the electronics dried out.
Plus the fresh gas and fuel stabilizer! Full Tank...run it a little to get the fuel up in the system.
