No Cost Oil Catcher
Old Dec 29, 2010 | 05:13 PM
Iron lHorse's Avatar
Iron lHorse
Originally Posted by midnight2005
Those of you that say that dry starting a motor does not hurt must have never seen the inside of a motor. You may not see the difference at first but it will take miles off the motor every time you do this.
Riding your bike like you just stole it. Happens more then oil changes. So I'm thinking the dry start for 15 or 20 sec is nothing compared to a day of fun with your freinds. Did I just say I beat my bike.
Old Dec 29, 2010 | 05:14 PM
TORQUEY's Avatar
TORQUEY
ALWAYS put some oil in an oil filter before installing it on any vehicle, including the lawn tractor.
Old Dec 29, 2010 | 05:16 PM
cHarley's Avatar
cHarley
Originally Posted by FroggyFatBoy
the only time i have ever poured oil in a oil filter before installing it is when its a fresh engine build. other than that, i've never gave it a second thought. a solid engine will retain enough oil on all neccessary surfaces until the pressure comes up.
The EVO oil system, which works on flow not pressure, is going to take a fair amount of time to pump nearly 1/4 quart of oil into the filter before anything can flow out of the filter. Combine that with air in the oil lines from being drained, and common sense tells me to play it safe and pre-fill the filter as called for in the Service Manual.
If you've got the new filter in you hand, why not fill it?
But, it's your motor..........
Old Dec 29, 2010 | 05:59 PM
FroggyFatBoy's Avatar
FroggyFatBoy
i admit, i'm not familiar with the evo oil system. is it going to hurt to fill the filter first, absolutely not, will your engine grenade on start up if you don't i doubt it very much.. if it does it was ready to pop before the oil change.. i've had numerous cager engines go well over 200k and never had a cyl head or oil pan off.. putting oil in a filter when changing it is something to make the owner feel good and won't have any adverse effect on the engine in any way.. but thats just my 30 yrs of wrenching experience opinion..
Old Dec 29, 2010 | 06:04 PM
CEJohnson21's Avatar
CEJohnson21
Thanks for this website. I added it to my favorites.
Old Dec 29, 2010 | 09:47 PM
HarleyScuba's Avatar
HarleyScuba
Old Dec 29, 2010 | 10:13 PM
Mal74's Avatar
Mal74
I've been using the coke bottle technique for years, but a bit different.
Cut the bottom out of the 2 liter bottle. Cut a slot up the side of the bottle for the socket wrench to stick out. Leave the cap on the bottle.
Once you get the old filter seal 'broken' slide the bottomless coke bottle around he filter. The slot cut up the side lets you turn the socket wrench till the filter falls into the bottle. By leaving the cap on the bottle you're able to catch the filter and drained oil with no need for a catch pan.
Old Dec 29, 2010 | 11:28 PM
Motorbones's Avatar
Motorbones
Originally Posted by XL50#674
I never put oil in the new filter, but I do rub some oil on the seal. I mean it's not going to hurt the engine to start it up after an oil change. I know a guy that pulls the plug wires after the LOF and then holds the starter on for a few seconds to pump oil, but to me there is no differant in that then if the engine just starts.
From what I understand, one of the benefits of sythetic is it tends to coat the metal better than dino... and I do admit I've never hear of pre-filling the filter before. I just fill the reservoir, start it up and let it slow idle for about a minute and then double check the level (more as a point to make sure there isn't too much oil in the motor)..
Old Dec 30, 2010 | 05:05 AM
TwiZted Biker's Avatar
TwiZted Biker
A little oil priming in a new filter is a given , doesn't hurt anything not too now does it ? That cute grabber end wrench isn't going to last long I've seen some of the filters on so tight we literally drove a punch through them to get them loose sometimes . I favorite is the strap style you wrap completely around it .
Old Dec 30, 2010 | 07:00 AM
Beercan321's Avatar
Beercan321
+1
If it has a filter I always prime it before installation.
