ugliest motor ever
ugliest motor ever
For the last week I've been trying to clean this damn engine, its out of the frame and sitting in my living room on on an engine stand thats bolted to an old table... my girl does not particularly like this boo hoo! I've tried brass wire brushes, paint stripper, scotch brite pads, degreaser, gunk, a whole lot of elbow grease and I am real close to getting out the big guns (power tools). This thing is about as old as me and just about as stubborn too. Thinking now maybe I should just paint the dam thing wrinkle black and be done with it. After all I'm not particularly the kind that cares much about looks but it needs some TLC PDQ or the other half is gonna make sure i'm MIA. Anybody has any ideas or been down this road before your input would be greatly appreciated
Find a shop that has a big enough vat full of carb cleaner that'll let you submerse it for a few days and give it a good soakin'. Should be safe for aluminum, cast and lighter metals. This is assuming that you are intending to overhaul it?
Yea I just went through the top and bottom ends and surprisingly enough it looks like everything is in order, even had a new Torrington bearing, Jim's lifters, new cam and adjustable pushrods. Thats not a bad idea, its so dirty that I can't tell whats old dried up oil and whats paint. I would probably want to take that plastic breather gear out though so the chemicals don't eat that up. Anomymous_1 has a point too and I've heard that paint Harley sells is good stuff. I don't understand why the dude that sold it to me would go through all that work in the bottom end and not spray it with a hose every once in a while
Another option would be to find a shop that has one of the vertical parts washers/machines. They use a water based chemical with high pressure and heat. Works real good on stuff like heads, intakes, etc.
Or...put it in a bead blaster to really clean it up. Just be sure it's sealed up tight. Of course it'll FU any shiny stuff that's on it most likely...
Had a neighbor once who cleaned his KZ 900 engine with Easy-Off. It looked great for about 2 days. Then, all this oxidized crud started to grow on it. I don't think you could even tell where the fins were after a while. Looked like a robot threw up on it.
yea I got some of that aluminum wheel polisher I wonder if thats the same stuff you're talking about. Hey by the way didn't I see that Triumph in an issue of the horse? Cool bike either way
