Seat problem
Old Mar 16, 2011 | 01:41 AM
mikeymike50's Avatar
mikeymike50
Default Seat problem
What's the best way to bend the front metal tab so I can move the seat A half inch. Forward so the seat will seat properly to the frame the seat Pan is made out of fiberglass and I'm afraid if I try to bend the tab it will crack the fiberglass any suggestion would be appreciated
Old Mar 16, 2011 | 03:37 AM
oct1949's Avatar
oct1949
remove the tang tab, make alterations to it, put the tang tab back on.
Old Mar 18, 2011 | 07:55 PM
ffatboy03's Avatar
ffatboy03
I had to move the tab on my seat because I couldn't get it under the frame. I had an upholstering shop pull the seat cover off. I drilled the rivets out and put spacers in between the seat and the tab. Kind of a hassle, but better than bending the tab and breaking your seat pan. Also the tab is fairly thick. Might be hard to bend. Hope you get it worked out.
Old Mar 18, 2011 | 08:17 PM
p51bombay's Avatar
p51bombay
Wont moving it forward cause the mounting screw to be out of alignment?
FLMARK
Aug 5, 2014 02:49 PM
stickystuff
Jun 13, 2012 09:45 PM
christer_malmesjo@hotmail.com
May 2, 2012 11:53 AM
mikeymike50
General Topics/Tech Tips
Mar 15, 2011 04:12 PM
ken01976
Dec 13, 2007 10:17 AM
