HD RIDE PLANNER download to NUVI.
I have the Garmin Zumo 550 and LOVE IT! I download my saved rides from the HD website to my Zumo easily and flawlessly.
Here is my question: You can not do the above with the Nuvi. Garmin even says so. Has anyone been able to do it? I think my friend has a Nuvi 255 but eitherway, has anyone been successful d/ling from the HD Web Site rides to their NUVI?
Thank you in advance!
BuzzCap7
BuzzCap7
It will depend on the Nuvi model or the specific model of any other mfg. for that matter. The key, is usually in the "Specifications" section for your particular unit. Look for a spec. that says "Routes = xx". If your model doesn't list this, or says "Routes = 0", then you are SOL.
The ability to store route plans in the GPS, is typically found only in the higher end GPS models. To my knowledge, the 255 Nuvi does not support stored Routes. I believe the 265 Nuvi is the lowest model that has that capability.
Works on Nuvi 750, but your maps need to be up to date. Mine are 08 maps without some completed roads on it. Ride free will have the new road and when it transfers it Nuvi reroutes not knowing about the completed rd. Makes since but you need to check your downloaded route.
You can go to Garmin's website and get the specs for each of their models.
As mentioned, look for the spec "Routes = xx"
xx = number of routes capable.
I just last night made a "test map" on the Rideplanner thing that I will try to load on my Garmin Streetpilot c580. I can't find anything on the "specs" for my unit except that it accepts custom maps. Hope it works.
You can load new maps, as they release updated maps 2 or 3 times a year.
But when you use something like Ride Planner, you are creating a custom route.
You can then transfer this route to a GPS that supports custom routes.
You need a route capable GPS in order to do this.
OK, thanks guys. One of these days I'll buy a new GPS and I'll have to look for one that will accept routes AND play my MP3's!
Don't know much about this hitech chit but I have no problem downloading from the ride planner to a very old Garmin Quest sometimes rtes are not exact because of road changes but it always gets me close on a long trip. Especially since I don't use interstates unless it is absolutely necessary. A trip is to relax not rush it.
HD Ride Planner to Garmin Nuvi 1450LMT
Hey now!!
I am using HD Ride Planner with the Nuvi 1450LMT.
I have created a ride with 13 locations. Then I created a name for the ride and clicked to save. (It says save successful.) I then go to "GPS Synchronization" and click detect my device. It finds the Nuvi and allows me to export the ride to GPS. (It says "Export Complete".)
My question is: Where do I find the ride on the GPS? I'm assuming I should see an entry somewhere which has the same name as the name I chose when I created the ride.
I can see all of the locations named individually in the "Favorites" section, but shouldn't I see the ride I created and be able to click on it and go from the first location to the last?
(This is how it works in Garmin Base Camp, but I'd prefer to use HD Ride Planner because it uses Google Maps which is so much more accurate and detailed.)
Any help would be greatly appreciated!!
