Oil residue in breather; 2001 TC88
Old May 8, 2011 | 03:08 PM
Mudflat194's Avatar
Mudflat194
Stage II
Default Oil residue in breather; 2001 TC88
When I run my 2001 bagger hard (highway speeds) I get oil residue in the bottom of my breather cover oily drip deposits timing cover under the breather. Burns about a quart every 1,000--if run hard.
This does not occur when run easy around town.
Before I take it the dealer, opinions? suggestions?
Old May 8, 2011 | 05:22 PM
midnight2005's Avatar
midnight2005
oil level is too full
Old May 8, 2011 | 05:24 PM
harleydavis's Avatar
harleydavis
Pretty normal if you have the old style air filter backing plate that has the hose from the breathers coming into the bottom of the backing plate. The Screaming Eagle style has it coming into the throat of the carburetor, or EFI, so it will be sucked back into the intake and ignited in the heads.
Old May 8, 2011 | 06:28 PM
seniorsuperglideE8's Avatar
seniorsuperglideE8
There are a couple of options besides keeping your oil level a bit under full when hot. Replacing the umbrella valves inside the rocker boxes or using the new vent free rocker boxes from TP Engineering.
Old May 8, 2011 | 06:37 PM
Stiggy's Avatar
Stiggy
Definitely look at the umbrella vales. You shouldn't need to add oil between 5000 mile services.
imbuhlman
Oil Archive (no new posts)
Apr 28, 2017 08:35 PM
safetydave7777
Aug 3, 2011 08:17 PM
harley#1
Apr 24, 2010 05:47 PM
Stvsdrs
Aug 23, 2009 02:10 PM
Hickey
Aug 10, 2009 02:28 PM
