Added a Extra 1/2 Quart
Old May 31, 2011 | 09:07 PM
FastHoss's Avatar
FastHoss
Default Added a Extra 1/2 Quart
I don't remember who posted this but in effect said the 5 speeds need a extra half quart in the primary.I thought I would try it this time,filling to the bottom of the spring instead of the quart the manuel calls for.It works really good,trans is a lot smoother,alot less cluncking.
Old May 31, 2011 | 09:50 PM
xxxflhrci's Avatar
xxxflhrci
I fail to see how the tranny would be smoother with more oil in the primary. At any rate, too much oil is likely to cause some drag and rob you of a pony or two.
Old May 31, 2011 | 09:56 PM
Bluehighways's Avatar
Bluehighways
Biggest issue with an overfill of oil is that the pressure on the transmission seals exceeds their capability. As a result they develop leaks that only replacing the seals will repair. This may take a while depending on how hard you ride . . . putting sawdust in a gear box will also quiet it down . . . but that doesn't mean it's a good thing to do.
Old May 31, 2011 | 11:12 PM
Other Sheep's Avatar
Other Sheep
He said primary.
Old Jun 1, 2011 | 07:14 AM
OldMike's Avatar
OldMike
Filling to the bottom of the clutch spring IS the correct amount, I don't get your post.
Old Jun 1, 2011 | 07:26 AM
1flhtk4me's Avatar
1flhtk4me
I could not tell the difference.
Old Jun 1, 2011 | 10:24 AM
lo-rider's Avatar
lo-rider
...need a extra half quart in the primary.I thought I would try it this time,filling to the bottom of the spring instead of the quart the manuel calls for.It works really good,trans is a lot smoother,alot less cluncking.
*B.S.*
Old Jun 1, 2011 | 07:26 PM
FastHoss's Avatar
FastHoss
The manuel calls for 32 ounces.Follwed someones post and added about a half quart more oil to the primary brining the level to the bottom of clutch spring.Big differnce in the way it shifts ,nothing to do with the trans.clutch works a lot better.I thought it funny the newer bikes with the same primary except with no insection cover take more oil.Kind of reminds me of when the Harley manuel called for foot pounds when they meant inch pounds on the cam plate.If you have a 5 speed try it for a couple of days,drain it if you don't like it.My guess is you will leave it like I did.
Old Jun 1, 2011 | 08:06 PM
zukeeper's Avatar
zukeeper
an extra HALF A QUART !! no way dude . recommended puts both 5 speeds we own almost on the money , a touch more and its there. overfilling will just cause you grief. and like was already said , filling to the bottom of the spring is the correct amount
Old Jun 1, 2011 | 08:56 PM
Bluehighways
Originally Posted by Other Sheep
He said primary.
Same answer.
