Is it time to change oil?
I have an 07 Ultra with 4800 miles. In October 2009 I changed all oil (Mobil V Twin syn) & filter and stored bike until May 2010. I used the bike until September 2010 and then it went back into storage until now. I put about 1200 miles on it last year. Business commitments out of town really screw my riding time.
Should I change oil and filter now or can I ride until October before putting her away?
Thanks
Thanks
You should never run oil past 5000 miles or 1 year in the sump of the engine. Primary & trans will be fine by mileage. If you run gear oil in the trans it can go 15,000 miles. I change my trans every 3 years.
Absolutely. Those additives in the oil do not last forever even if not used that often. You also want it stiing with the clean stuff inside.
Engine oil every 5000 miles or once a year. Which ever comes first. Use a good quality oil of your choice and change the other fluids per the schedule.
Thanks
Thanks
So...yah...service it and ride it. Hope your work load slows down soon.
my bike goes on the lift every winter for maintenance/mods and cleaning. i change all 3 fluids regardless of mileage. engine oil and filter every 5000 during the riding season. i go through alot of oil, but oil is cheap and engines are expensive.
that is one of the cheapest things you can do why not fall on the side of preventive maint, i do all holes before riding season and after riding season, am i **** yes but it peace of mine
Kozak
04-06-2008 09:03 AM
anubisss
07-11-2007 09:00 PM
