Tank Nameplate Install
Old 01-17-2007, 05:46 PM
hdjoe88's Avatar
hdjoe88
hdjoe88 is offline
Default Tank Nameplate Install
Any suggestions on installation of new gas tank nameplates. So far my plan is to locate one side and then measure off its location so as to mirror the other side. I was going badgeless but decided the tank needed something. I picked the early 60s Northstar nameplate.
Old 01-17-2007, 06:04 PM
huffhuff's Avatar
huffhuff
huffhuff is offline
Default RE: Tank Nameplate Install
my flhpi came badgeless. i used photos of a standard road king tank and measured from the front of the tank to the front of the V decal, determined the distance from the fuel cap to the decal, the distance from the chrome dash to the rear of the decal. this got me pretty close using those dimensions on both sides. it is rare for a harley decal or badge to be parallel to the ground. you may see many applied that way and i always notice them as i walk up. i used a grease pencil to make my line up marks. on a dark tank i'd use masking tapefor the grease pencil marks. using a badge as you are is easier than the decal. you can use masking tape to temporarily install the badge and walk away some to look over the results and move around to suit your taste.
Old 01-17-2007, 06:15 PM
hdjoe88's Avatar
hdjoe88
hdjoe88 is offline
Wouldn't you say that the nameplate (badge) should run on an up angle from rear to front i.e. going with flow of the tank? I hope I made that clear.
Old 01-17-2007, 06:42 PM
Tin Gizel's Avatar
Tin Gizel
Tin Gizel is offline
I would prefer mine to be at some sort of an angle....let's say for instance, the bottom of the tank is 0 degrees and the top is at 20 degrees....i would put my badge on at 10 degrees...
Or so i think, i guess the tape it and stand back and look method would be best....find what suits you and run with it.
enurdat1
10-19-2013 05:13 PM
DENGUY
02-14-2010 10:58 PM
Gman in NC
01-27-2010 02:54 PM
jgcable
01-31-2008 02:29 PM
1200c
01-04-2006 11:53 AM
Quick Reply: Tank Nameplate Install
