2012 Deluxe. I am going to check my rear axle alignment and would like to know if anyone has bought and used the rubber plugs for the axle ? Should I buy them ?
Any better way to check alignment ?
Thanx.
Thanx.
dont know bout the plugs, but when align the back end.. i eye the belt and make it straight, then i check the amount of flex in the belt (no more then 1/2 inch) then i check that the axel is about in the same position thru the swingarm and if it is, then i spin the tire to make sure the drive belt doesnt move on the pulley and if thats good then i tighten the axel bolt
don't know abput rubber plugs, but on my 12 touring bike i bought jim's axle tool and it works great. on my softail a just measured from the center of the axle to the center of the swingarm bolts.
My bike (an 06) has holes in the swing arm to measure from. You can use a measuring tape or cut and bend a coat hanger and use a tiny o-ring to mark the axle alignment. No need for big bucks toy tools.
I wish they still did that.It works great and is easy. I also wish they used a cam like the touring bike have for many years.
Thanx.
Some people with softies simply measure the threads on the axel adjuster bolt.
