New gaskets when opening up top end?
  #41
Old 06-30-2014, 01:20 PM
harleycharlie1992's Avatar
harleycharlie1992
harleycharlie1992 is offline
Unofficial HDF Chaplain
Received 15,177 Likes on 4,773 Posts
Originally Posted by mmancuso
The correct way is any way that results in an engine that is running with no problems.
You tell me...who do you think determines the "correct" way?
I'll tell you: it is a way that has been determined and documented through practice to be the most efficient way to tear down and reconstruct the engine such that it runs with no problems. That does not mean it is the only way.
by the way, by your standard, of the correct way, this person did it the wrong way!!
  #42
Old 06-30-2014, 01:30 PM
05flhtbob's Avatar
05flhtbob
05flhtbob is offline
Received 10,654 Likes on 1,731 Posts
no body is going to win this one either
  #43
Old 06-30-2014, 01:44 PM
harleycharlie1992
agreed! and I mentioned that just a bit earlier
  #44
Old 06-30-2014, 01:50 PM
wraplock's Avatar
wraplock
wraplock is offline
Some of us on here have or are currently making a living working on these bikes. Those of us who do or did (and I am one) know what is right from wrong. No point in arguing with people who ask questions like "Where do you put your gas cap while fueling", etc...etc...etc. A professional would never reuse a gasket. If/when a leak developed it would reflect poorly on the quality of his work. As a customer, if I found that the shop reused gaskets I would NEVER return. No excuse would be acceptable to me. What you do in your back yard is your business. If you find reusing gaskets to be an acceptable practice then by all means continue. I've made a pretty good living straightening out other peoples F@*k ups!
  #45
mmancuso's Avatar
mmancuso
mmancuso is offline
Originally Posted by harleycharlie1992
to be sure, and I stated this before, I didn't insult the person, I called his decision to reuse gaskets, stupid, not him. my statement will stand, as I know from all that you told us what make the right way to repair a motor, thru experience, that , the repair will fail, and will start leaking in the not too far off future.
And here is where we'll just have to agree to disagree.
I used to wrench my own Jeep Cherokee in the 80's, which I 4-wheeled with all over southern California. I re-used gaskets in several areas and over years I never had them leak on me.
Your prognostication of failure is not a certainty, no matter how certain you are.
I would certainly consider that the gasket leaking is a repair failure, either now or in the future. Whether or not, the person knows that his repair is sabotaged, by reusing gaskets is irrelevant, the end result is still the same. since this conversation is theoretical, both because we will never know the actual outcome, or when it will happen, I suggest we just agree to disagree, as we will never get the proof we need to prove our points.
Everything fails, and you're taking the safe stance that says if there was a failure in this particular area, then "this" is why. You can't lose because all you have to do is wait for it to fail no matter how long it takes.
Agreed to disagree.
  #46
Old 06-30-2014, 01:53 PM
mmancuso's Avatar
mmancuso
mmancuso is offline
As you said, "If/when a leak developed...", and the key word is "if", not the certainty that some seem to have of "when".
Working on other people's rides has already been addressed, and no one here, at least not myself, has suggested re-using anything on someone else's ride.
  #47
Old 06-30-2014, 01:58 PM
mmancuso's Avatar
mmancuso
mmancuso is offline
The original op was discussing another rider who did his own wrenching, and here's what he said:
Now the interesting part was he said he didnt even have to use new gaskets. When he took cam cover off the gasket was clean, didnt peel off or break and looked brand new so he reused it. Same with top end. No leaks, bike runs great, and he had about 29k miles on bike.
So....what was the wrong way other than the disagreement with reuse?
Rhetorical, beat to death.
I'm just not as sure of anything as some of you seem to be.
  #48
Old 06-30-2014, 04:23 PM
superman70's Avatar
superman70
superman70 is offline
Only problem is that you do the work and not change gaskets you have to do it over.
  #49
Old 07-01-2014, 10:35 AM
ohioflhs's Avatar
ohioflhs
ohioflhs is offline
If I recall correctly, my EVO had rubber gaskets in the top end. I reused them once or twice but if it leaked it would have taken me around about 10 minutes to change them. Why not try to reuse them? What's ten minutes?
Back in the seventies when we had to adjust valves from time to time in our cars, we would make sure we used rubber gaskets that could be reused several times.
  #50
Old 07-01-2014, 02:03 PM
AJSHOVEL's Avatar
AJSHOVEL
AJSHOVEL is offline
Received 10,575 Likes on 4,169 Posts
You can do a top end in ten minutes?
We're not talking about valve cover gaskets here.
Quick Reply: New gaskets when opening up top end?
