Fork mount signal install question
Old Mar 19, 2017 | 06:03 PM
Jhub003's Avatar
Jhub003
1st Gear
Default Fork mount signal install question
Whats the easiest way to lower my front forks on my 2016 dyna to mount my joker machine fork mount signals? Is it necessary to remove my axle and wheel?
The signals are the joker machine fork mounts http://www.jokermachine.com/harley-d...er-lights.html
Any tips?
Cheers
Old Mar 19, 2017 | 08:26 PM
Ghost_13's Avatar
Ghost_13
Any tips?
Cheers
This is going to be a long one
Is it necessary to remove the wheel - strictly speaking - no..., but it will make things a whole lot easier
And you may need to remove the brake caliper - depending on the brake cable length
What you didn't say - are you planning to mount the signal lights just below the upper tree..., between the upper and lower...., just above the lower..., just below the lower
This is going to make all the difference in the world
Never the less
Place the bike on a jack..., jack it up till the wheels about an inch or so off the ground
Strap it down tight - especially the front..., so it doesn't raise when the forks removed..., and the bike becomes *** end heavy..., then tries to fall off the jack backwards
Remove the brake caliper and wheel - takes longer..., but make it easier for you to manhandle the forks off..., and back on
Remove the fender - so both forks are independent of one another
Loosen one side's lower pinch bolt..., then that same side's upper pinch bolt (order doesn't really matter) but what does is that as you loosen the last of these two pinch bolts on one side - you hold firmly onto the fork as it will want to slip down
Once loosen slide it down carefully (this is where scratches could occur - if the do no biggie it only war wounds)..., install the signal light at the desired location..., slide fork back up into position
Important
Before removing either fork - measure the distance the fork currently above the upper tree - reinstall at that same exact distance..., not close - exactly
Torque the pinch bolts to factory spec - top is a different setting than the bottom - be sure to torque in stages - iow don't go all ape on it - all at once
Repeat for the other fork
Then reinstall fender..., wheel..., brake caliper
Wire up the lights... test..., you're off to the races
May seem complicated - it ain't..., just take patience and attention to detail
Ghost
Old Mar 20, 2017 | 07:10 AM
grbrown's Avatar
grbrown
Wink
Further to Ghosts instructions, once you have the forks and wheel back in place, tighten the top tree clamp bolts, to secure the tops of the legs. Only nip up all other fasteners, do not torque them up just yet. With your bike back on the ground, apply the front brake and pump the forks up and down a few times. This will align the tubes in the bottom tree and minimise the risk of the fork legs binding. Then torque everything to spec. Hope that helps!
ole_phart
2018+ Softail Models
Jan 30, 2019 10:42 PM
liquidr1
Nov 5, 2017 08:06 PM
gatorfrey
Oct 19, 2014 04:20 PM
meepers
Apr 5, 2010 11:40 AM
osirisdean
Feb 24, 2010 07:00 AM
