General Topics/Tech TipsDiscussion on break in periods, rider comfort, seats and pad suggestions. Tech tips as they become available will be posted here.
Any chance you've got a pic of that? Just be careful to not squish any lines, can't picture it; particularly for a dyna FXDF?
Was not intended to show up the wooden planks, but if you look well you can see one under the frame. Does not need to be thick and certainly not wide, just enough to support the frame. They can move a bit when you roll the lift under. So before actual lifting check if they are positioned with centerline of the plank directly under the frame bars. I got later those frame supports from HD that hold on to the frame rather than being loosely placed on the lift. This avoids the hassle with planks not aligned properly. That's in the other picture ( items in orange, zoom in) Check the HD catalog for that under section lifts.
I use a couple of 3/8" rubber shims cut from floor tiles when I lift my Heritage on my J&S jack. Put them under the frame tubes in the back member. Works perfectly to clear the shocks. Wood shims would work, too, pretty much anything.
That said, I've read somewhere on this Forum (from people who should know) that it's not a problem to lift the old softails with pressure on the shocks. But for the 10 seconds it takes to place the shims, why take a chance?
