Rear wheel adjusting while riding
Old Sep 19, 2017 | 09:26 AM
Bobbed's Avatar
Bobbed
Default Rear wheel adjusting while riding
A bit about the bike: Custom rolling thunder hardtail frame with a 250 rear tire, driven by an open belt system and has an evo motor in it. I took it out this morning and while riding it felt a bit different. I noticed that my rear tire would start shifting, on the right side, back and forth. Checked it and the bolt is as tight as can be.
Not sure what the issue is? Maybe the chain is too tight?
Old Sep 19, 2017 | 09:29 AM
Pachuco's Avatar
Pachuco
Check your wheel bearing...looks like it might be going out.
Old Sep 19, 2017 | 09:31 AM
MURPHCC1's Avatar
MURPHCC1
What about the adjuster(circled)..........
Old Sep 19, 2017 | 09:34 AM
grbrown's Avatar
grbrown
Wink
It may well be 'tight', however I recommend you dismantle it and study closely everything you disturb. It obviously isn't actually tight, otherwise it wouldn't move! It looks as if there is an adjuster hiding in front of your axle, so if they are both correctly adjusted, the axle shouldn't move.
Rolling Thunder are still around, so check with them what your rear wheel set-up should be, in other words what spacers etc it should have and what order they should be assembled in.
Old Sep 19, 2017 | 09:41 AM
Uncle Larry's Avatar
Uncle Larry
Missing pieces ...
Old Oct 12, 2017 | 10:11 PM
canyoncritter's Avatar
canyoncritter
To me it dosen't look like enough material to make a clamping bond or something missing.
Old Oct 13, 2017 | 02:43 PM
fireman031967's Avatar
fireman031967
Check the frame welds. Rode with some folks that had one of those, rode over a rise with a dip on the other side, frame weld broke and it sat flat on the pavement. They wound up waiting on a flatbed after we carried the bike off the road.
Old Oct 13, 2017 | 04:05 PM
Mr-Mike's Avatar
Mr-Mike
missing a spacer?
Old Oct 14, 2017 | 12:18 PM
bustert's Avatar
bustert
++++1 mr. mike
the bolt can be tight against the axle assy but not against the frame. the frame should have a slight squeeze.
Old Oct 14, 2017 | 02:07 PM
hardheaded's Avatar
hardheaded
looking at the spacer between the frame and bearing something looks loose. bad bearings or missing internal spacer. spacers on the wrong side of the wheel ?
