fxr rebuild
Old Mar 2, 2018 | 08:12 PM
pppk's Avatar
pppk
3rd Gear
Default fxr rebuild
i have a couple questions with hopes i can someone can help me out
i have a 1988 fxr and i am gona make the attempt to change the rocker boxes myself to save a few bucks so can someone plz give me the exact process of doing so as detailed as possible
also how do i tell the difference between pushrods if they are not colour coded and have bin mixed up
any help is muchly appreciated
Old Mar 2, 2018 | 08:35 PM
98hotrodfatboy's Avatar
98hotrodfatboy
First off, you should have a factory Service manual..... Get one, they're only $60 from the dealer... Starting with the shortest pushrod and moving up to the longest the position is as follows. Shortest-rear intake, the next shortest-front intake, the next shortest-rear exhaust and the longest-front exhaust.
oh yea Incase I forget, get a FSM...
Old Mar 2, 2018 | 08:52 PM
pppk's Avatar
pppk
3rd Gear
ok thank you i will be getting a manual right away
Old Mar 3, 2018 | 11:19 PM
pppk's Avatar
pppk
3rd Gear
Default fxr
theres a bang type sound wen i go to start my bike not sure the cause any ideas?
Old Mar 3, 2018 | 11:20 PM
pppk's Avatar
pppk
3rd Gear
got the manual now to
Old Mar 4, 2018 | 06:28 AM
98hotrodfatboy
After you installed the pushrods did you turn the motor over by hand to make sure all the valves are adjusted properly and not smacking a piston?
Old Mar 4, 2018 | 06:47 AM
Dan89FLSTC's Avatar
Dan89FLSTC
Active Streak: 30 Days
When you get your factory service manual, be sure to follow the procedure carefully.
If you do not follow the procedure exactly as it is written, you will be back here asking why you have a bent pushrod or valve.
Old Mar 4, 2018 | 07:43 AM
pppk's Avatar
pppk
3rd Gear
yhx i let u no how i make out
Old Mar 5, 2018 | 10:50 AM
grbrown's Avatar
grbrown
Best of luck! For future reference we have a dedicated Evo section, where you can meet up with fellow owners, so call in there.
Old Mar 7, 2018 | 07:59 AM
pppk's Avatar
pppk
3rd Gear
ok i got everything buttoned up just waiting to get tank and fenders back from paint...
just wanted to be certain....does my motor gota be at tdc before starting?
