Evo exhaust gasket in 103 twin cAm
had my Indy install some headers awhile ago because I couldn’t get them to seal with the SE ones or stock ones. It appears he used so evo ones because they’re the diameter of the exhaust port but a lot shorter. They didn’t come all the way to the edge. They sealed great but had anyone heard of doing this before? I have a 2015 street glide
The flat gaskets are the old stock gaskets it wasn't until like the mid 90's that they switch to a tapered gasket to go with the tapered seat of their header pipes. Not sure how a flat gasket could be too thick for the headers though, you kind of lost me on that comment as most AM pipes are designed for the flat type gaskets and not the tapered type. The SE gasket is just the flat type gasket and not the tapered. I have even been told by a dealer mechanic to use 2 gaskets if one continues to leak.
As said, either tapered or flat depending on the exhaust... The flats gaskets nor the port diameter have not changed in decades, however i have seen some flat gaskets that were not manufactured properly (cometic) And I sent them pics and they sent me back several pairs of the correct size.
