Stainless Steel Fastener Questions
I removed engine and trans covers to get them powder coated and I'm looking to replace the fasteners to SS since I already have them out. I scoured the inter-webs as well as these forums and have learned a LOT, but I still have a few questions. In no particular order....
Thanks in advance for your replies
- Will a grade 8 SS bolt be any more, or less, prone to galling than a standard grade SS bolt provided that they are installed slowly (no power tools) to avoid excess heat, properly torqued using an inch pound torque wrench , and using proper thread lubrication?
- I know what the manufacturers recommend, but what are YOUR experiences using anti-seize vs blue loctite , vs TefGel? Anti-seize makes the most sense for lubrication and to eliminate galling but i fear that they will constantly need to be re torqued.
- Any mechanical advantage to using 12pt vs Allen or is it just cosmetic? I actually prefer the look of the Allen head bolts
- Any personal experience on the the difference between "polished", "show polished" from AlloyBoltz or the offering from Gardner Wescott, Diamond etc. I like a clean polished look but don't care (necessarily like) chrome on this build.
- Any pictures of these fasteners installed on a black primary, derby, clutch cover etc. would be appreciated.
Grade 8 will be fine.
I use blue loctite with the exception of the exhaust nuts No problems in 6yrs.
Advantage of 12pt compared to Allen? Don't know. I use 12pts with no complaints so far.
Polished bolts retain the ARP lettering, Show polished have no markings. Purely cosmetic,
Pics? Don't have any. But the show polished look much nicer IMHO.
Sarsippius (05-30-2019)
I just put the whole engine kit from alloy bolts on over the winter...the stainless ones with the allen head. I used a little dab of never seize and so far in 2500 miles this season not a single one has backed out or needed to be retorqued. Just pay attention because the torque specs change when using never seize. Just my opinion but a grade 8 bolt on any of these covers seems to be over kill. I tried to get bolts from the hardware store but after a lot of hunting and always coming up short ...literally...i gave up and just paid for the set...which is worth the money just for the convenience. My cases are chrome so no sense posting pictures...but they look great
Ace hardware ss screws
You don't need a grade 8 screw for your cam cover, primary, lifter blocks ect. Almost all of those are 1/4-20. A dab of grease on the stainless steel threads and then tork them down. I've been doing this to all my bikes for the last 20 years. never had ANY problems. I did polish the heads with chrome polish.
Thanks for picture. That looks bad ***!
bigal51 (05-31-2019)
Thanks for the info. The more I read these responses the better I feel about the galling. I've heard horror stories and wanted to make sure I knew what I was getting into before I jumped.
