99 electra glide
Old Dec 26, 2020 | 08:59 AM
Brandonsnelly's Avatar
Brandonsnelly
5th Gear
Default 99 electra glide
Does anyone have a suggestion on raising the seat to lift it off of the hard bags? Other than losing weight.
Old Dec 26, 2020 | 09:09 AM
dawg's Avatar
dawg
How wide is your seat? Generally only the rear passenger portion is next to the bags and it is thinner than the rider portion. Got a pic of you seat on the bags?
Old Dec 26, 2020 | 10:58 AM
Brandonsnelly
5th Gear
It's 17 inches. I want to put stretched bags on it. But I don't want to do the same thing to new bags.
It is a road king seat though.
Old Dec 26, 2020 | 11:04 AM
brakeless's Avatar
brakeless
If that seat has those rubber screw in bumpers under that sit on the fender or frame you can put spacers under them and use longer screws. Same with the tab at the back if that's the case. Or even make a new tab with a drop bend. The local Ace has bins of rubber bumpers.
Old Dec 26, 2020 | 11:11 AM
Brandonsnelly
5th Gear
Ok I will look thanks.
Old Dec 26, 2020 | 01:01 PM
im's Avatar
im
As mentioned.
There are two brackets bolted to frame on each side of bike.
The two bolts or zeus fasteners in each saddlebag then attach to those two brackets.
Place a spacer or ( 4 washers) under each bracket and then use longer bolts for those brackets.
The saddlebags will then angle away from frame.
Under $10 USA dollars for bolts and washers.
Old Dec 26, 2020 | 01:04 PM
brakeless's Avatar
brakeless
Originally Posted by im
As mentioned.
Great option im! I was more focused on raising the seat.
Killaglide
2018+ Softail Models
Mar 27, 2020 09:26 AM
Bigjohn1381
Oct 17, 2019 08:36 PM
GoofySB
Jul 8, 2016 09:14 AM
lowglide88
EVO
Feb 8, 2007 08:55 AM
mikael
Dec 29, 2006 06:41 AM
