Sub-Zero temperatures
big difference in a stove burner and a heater that sounds like a jet engine in comparison.
carbon monoxide builds up in your system faster than your body can get rid of it . you can spend time today around a heater with no problems, go back tomorrow do the same thing you might begin to get a headache start getting dizzy . if you think propane salamander heaters are safe put a carbon monoxide detector in your shop or shed and run the heater and see if it goes off.
Carbon Monoxide (CO) and Propane
Carbon Monoxide (CO) is responsible for almost 25% of all propane related fatalities. Carbon Monoxide is the product of incomplete gas combustion often because appliances are improperly adjusted. Properly functioning propane appliances will produce what is called an "ideal burn" during combustion and present no danger of Carbon Monoxide poisoning. Carbon Monoxide poisoning can lead to severe injury and even death.off propane 101 site. note: CORRECTLY burning.
i have a fake log heater and it purposely burns with yellow tips to mimic actual logs burning. even with the yellow tips as long as the base is correctly colored, the yellow tips offer very little harm. now if i had a super sealed house, maybe then i would be concerned but going back 80 years, not even close. the unit is tested and approved by big brother and it is a ventless model so 100% heat stays in the house.
Two bike in unheated garage now . One of mine and one belongs to a friend . We have had a lot of sub zero days of 25 below and that is not wind chill. Pretty much normal here. Never been an issue. Just plug in battery tender and leave it alone.
To the OP. Forget about the weather temperature having any affect on your bike. It doesn't no matter how cold it gets. It's just like a car or any other vehicle that is designed and constructed for outdoor use exclusively. It is almost entirely weather proof. It doesn't need a warm place to stay. The one exception is when a warm temperature (say above 50) follows immediately a sub freezing period. That will cause condensation to form on a bike. Just like a cold beer can does when it gets exposed to a warm humid day in the summer. It will evaporate on its own as long as it's in open air. Not under vinyl or any other non-breathing material. However, there are some metal bike components that can react to the condensation and form rust or corrosion. Any salt presence will accelerate that process. So rest easy. Your bike will be fine. And wait for good weather to ride safely and comfortably. You'll be happy you did.
read what it says, ideal burn. it does not say total burn. so yes there will be trace amounts but under normal circumstances, it would take a VERY long time to build up and you would need a pretty sealed up room. since my house is natural gas sourced, i have monitors and NEVER in 47 years has there been an issue. before i used kerosene heater that was pretty clean burning but after a few years, the house took on a smell from it. i have central gas fired unit but use space heater of the fake log type to mainly heat the house. my older central unit was not very thrifty being maybe 60 cents to the dollar, my new unit is 80>90% thrifty but my space heater is near 100%, remember it is flue less. i guess decades of data in your eyes is faulted, but deff not in your favor. i am more worried about radon emissions than co and that isn't very much up on the scale either.
you dont need an air tight room to run into problems. it's accumulative in you blood i got sick from it sitting out side. i was a firefighter and i went to a chimney fire one night and a house fire the next day, and worked as a mechanic driving the cars in and out of the shop. all three built up enough co in my blood to make me sick. and if you smoke which i do it build up even faster.
it's been a while but if i remember right it takes like 12 hrs for it to be out of your system. one of my last calls we had a dad and his son die from a 1/4 " hole in a chimney for a gas fired hot water heater . old drafty house and the water heater vented thru the chimney for the house. there was a 6' section of galvanized stove pipe. their bed rooms where on the opposite end of the house. they where complaining of the flu two days before.
I apologize as this is a bit off-topic
Years ago (maybe 1970's) I remember my parents using a standalone kerosene heater in the house during some cold winters. Wouldn't there be a CO issue with those types of heaters just like there is with propane as mentioned in this thread?
Everytime you thaw it out with that propane heater, you're creating a **** ton of moisture both inside and out. Leave it be or run that heater all the time. One or the other. That moisture, inside the engine especially, is waayyy not cool.
